Results 3,601 to 3,610 of 7178
June 16th, 2013 10:41 AM #3601
Upon hearing rumors that seaoil has now gone to as low as euro II, I tried Unioil Euro IV diesel yesterday morning. Its a good thing there is one nearby in Marikina. I also took a sample to see the transparency of the oil compared to the previous I used (Petron and Seaoil--sorry didnt have the old pictures of these anymore).
Based on initial observation:
1. Noticeably smoother than the seaoil (which is already a big improvement back then coming from petron TD)
2. Less..er smoke than Seaoil
3. Fuel color is less yellowish and more transparent than seaoil (and waay more transparent than petron TD)
4. No water contaminants (station based)
5. Cant see any small particles...basically good and clean.
HTH
June 16th, 2013 05:33 PM #3602
June 16th, 2013 06:23 PM #3603
There is only one station in Marikina sir and yes its in the Bayan Bayanan - Concepcion area beside St. Vincent Hospital. But before I did this, medyo did some research because I'm OC with the fuel I put in. I also researched if this station gets flooded and thankfully hindi naman except...yes nung Ondoy. There are also several tsikot members filling up at the same for over a year now.
- May 2013
- 46
June 17th, 2013 12:37 AM #3606
June 17th, 2013 09:40 AM #3607
May nakapansin ba re the door opening of the T6? Madalas kasi sakin humampas pabukas full open. Kinakabahan ako the door hinges might get dissaligned sooner or later. It has happened on numerous occasions already specially pag ang passanger hindi maingat sa pagbukas. Is this something to be concerned about?
- Dec 2012
- 31
June 17th, 2013 10:23 AM #3608yes, sir i think you should raise this concern to your dealer. ideally, it shud be on a firm, 3-way configuration. para kahit mahampas ng malakas na hangin di basta basta makaka umpog ng katabing sasakyan. sobrang bago pa unit natin para ma worn out agad yung stoppers on door hinges.
June 17th, 2013 10:51 AM #3609
Hi, Hindi naman missaligned na yung sa akin. Door is perfectly aligned and solid pero I agree with you dapat firm siya. I also checked other units, ganun talaga eh. May tendency na bumukas full open stressing the hinges lalu na kung inclined tapos bubuksan ang door.
Sabi naman ng casa hindi namna daw basta basta ma didissaligned ang pintuan. Hehehe
June 17th, 2013 12:04 PM #3610
looks like this version (7th Gen) will be its last After 36 Years, Subaru Is Ending The Legacy...
2020 Subaru Legacy
