look! ford everest 18" rims. pero wala naman atang nagbebenta ng rims ng everest nila, maganda na kasi di na kelangan palitan. hahaha.
Does anyone know if available yan dito? Thailand lang kasi available nung nagresearch ako.
They also have other products like
Parking Wizard - bumababa yung mirror pag nag-reverse para makita ang curb.
Okay products nila ha, convenience features ng Euro/High end cars na pwede ikabit sa econo/entry level cars.
Though I think its not normal and should not be the case....
Avoid going below 1/4 of your tank kasi diesel yan so you could've had a case of fuel sloshing inside the tank and taking in air. Try mo kargahan ng mas maraming amount of fuel and see how it goes.
There could also be an air leak in your system. Have it checked, nakakabuysit ang ganyan....
Sounds like:
A sensor(s) alarm, baka may nabasa during engine wash (if u did wash the engine);
Water in Fuel (WIF). It should warn you, but you can check the fuel filter. You can easily just drain the water from it.
Best to have its ECU read. Baka ECU error related problem din.
What are the specs of the few Wildtrak 4x4 units that arrived with the first batch (early 2012)? Automatic 2.2L?
*Cyferion matic lang po ba talaga ang wildtrak? kasi naka pag reserve kami ng manual na wildtrak dito sa cebu. sabi ng SA meron daw manual.
