Page 101 of 202 FirstFirst ... 5191979899100101102103104105111151201 ... LastLast
Results 2,001 to 2,020 of 7178
    May 2013
    *luigitiu
    Yes sir i will pag may napansin ako
    Jun 2009
    Hey guys. I have an engine noise problem. So pag umaga or basta first start of the day, pag engage ko sa drive may sound na tiktiktik coming from the engine then when you press the pedal na it becomes a little louder and dissipates when you release the gas. After about 5 mins when the engine is warm na, everything sounds normal na. Also pag park or neutral, no unusual noise and norma idle engine sound naman. Its only during the early moments of first using the car in the day that i experience this sound from the engine. So what i do, after driving out of the driveway, i drive really slow and avoid revving until i get out of the village, by that time engine is warm and noise is gone. Anybody experiencing this?
    Quote Originally Posted by dcph172 View Post
    1st time diesel user? The noise is probably the tappets which is more prominent dhring a cold start. If it goes away it should be normal. Also you will notice the first acceleration on first gear there will be a springy spund underneath. This too should be normal. However have it checked na din for peace of mind
    Sent from my GT-I9082 using Tapatalk 2
    Jun 2009
    Quote Originally Posted by Djerms View Post
    No sir. We've had diesels before and even older rangers but i dont recall having this kind of noise. Even our old pajero doesnt have this issue, pero it has a different kind noise, ung typical old diesel noise haha
    ill try to explain it sa casa next pms. Because by the time i get to casa, engine will be warm and wont have the symptoms na.
    Pa-tow mo sir. May ERA ka naman ata boss eh. Hehe. Para malamig pa din engine mo pagdating sa casa.
    Quote Originally Posted by timykoo View Post
    Hope you can update us of the prob if any
    May 2013
    Mga sir tanong ko lang kung alanganin ba itong size para sa gulong, 275 65 r18, nitto terra grappler? Ito kasi plano ko eh. Pag ganyan yang size kahit walang ng lift okay na? Hindi ba sasabit sa fender or anything? Or anong size ba ang pinakasafe, bukod sa same size ng stock hehe. TIA
    Quote Originally Posted by mavgp View Post
    Pasok yan sir.
    Brought my Ranger to Batangas today. Talagang kulang sa power - may kasabay akong Altis 1.6G along STAR, from 100-170 sabay lang acceleration namin, then nag 180 na siya and started inching away. Bago ako makahabol nag-exit na siya.
    We were 5 full sized adults on board though, but with the Ranger's supposed torque, it shouldn't have been a problem.
    Turbo lag is also crazy, practically no pulling power unless youre in the turbo range so you really have to shift a lot. Di tulad sa Fortuner - it's either ample power (before boost) or power overload (once turbo kicks).
    Right now on-board computer is showing 10 km/L. That's around 80 km city and 140 km highway. Will find out later when I gas up again kung ano mileage based on manual computation.
    Dec 2010
    Against a car, wala talagang laban sir. Sa pulling and hauling power pwede, Torque is 375 Nm at 1500-2500 rpm. Kailangan nasa range kayo sir above 1500 rpm before shifting to enjoy the ranger's torque.
    Quote Originally Posted by JX290 View Post
    Its a small displacement engine after all. Isipin nyo nalang na PUMA engine yan being used by the ford transit and the land rovers. Sobrang tibay ng engine na yan. Its not meant for speed.
    Kung alam nyo lang how the ranger (both 3.2 and 2.2) were tortured by the ranger odyssey team in Africa (witnessed by C! editor James Deakin), mabibilib kayo. 8000kms of punishment (with almost 200kms of sand driving). Being a first time ford tdci owner, got a lot of confidence from this.
    Going back..as I've said...turbo lag is sh!t LOL.
    Gas and diesel engines are way different. Gas engines are flat torque while diesel are picky. Once you go over, turbo would not spool as much as it isin the range. One advantage of NA engines vs turbo charged engines. Isama mo pa power to weight ratio as well as aerodynamics.
    Sir kng is right, it's not meant for speed. Haha
    Mar 2007
    Pasok yan.. sa stock rims ko ba ikabit?
    May 2013
    Quote Originally Posted by kng200 View Post
    hindi sir, bibili ako sidewinder, pero tinanong ko lang para makasigurado akong kasya. medyo lalabas sa fender dba? pero bibili naman ako ng fender flares eh haha. :D
    Mar 2007
    Sorry type error kanina. Pogi yan sir. Negative offset na sidewinder para sakto siya pag may flares na.
    Exactly. Pick up has much higher curb weight (1.8 tons) than passenger cars (1.2tons) though pickup has bigger engine. Plus fuel is different. Comparing it to Fortuner is closer match. Pero no match pa rin. Baka naman Ranger is not designed for quick acceleration but rather on economy & emission. Or Engine management system might be limiting the speed.
    i shift at >2000 rpm para may momentum.
    More likely because of the turbo lag of the Ranger since it's a lower displacement engine that relies more on forced induction to create power than form outright displacement as with the Dmax.
    Both Ranger & D-Max are turbo charged right? Ranger has VGT. Not sure with D-Max if Naka VGT. VGT is supposed to provide optimal air at all rpm range (addressing the lag). Looks like it's not. Better get bigger displacement for better acceleration.
    Quote Originally Posted by A-OK View Post
    I've never believed that vgts provides optimum power. Displacement pa din ang magdadala ng torque.
    Jul 2006
    Not so with the Korean diesels. The Santa Fe has a 2.2L eVGT diesel engine yet you cannot feel any turbo lag.
    Does Sta Fe have MT? Gear ratio I found is AT only. Comparing the gear ratios again. Sta Fe has the lowest 1st gear final ratio of 14 engine revolution per wheel revolution (3.789 x 3.684). It also has the lowest 5th gear final ratio of 2.7 engine revolution per wheel revolution (0.728 x 3.684).
    I remember somebody asking about the rpm at 100kph. They can check out this site to theoretically calculate the rpm. Just have to key in several data. Close to actual naman yun calculation. rpm&speedcalculator
    Gear Ratio D-max 4x2 Ranger MT Sta Fe 2.2 AT
    1st 4.008 5.441 3.789
    2nd 2.301 2.839 2.064
    3rd 1.427 1.721 1.421
    4th 1.000 1.223 1.034
    5th 0.745 1.000 0.728
    6th - 0.794 -
    Reverse 3.651 4.935 3.808
    Final Drive 4.300 3.55 3.684
    Hyundai Sante Fe | Auto Search Philippines
2012 Ford Ranger
