Results 11 to 20 of 21
August 6th, 2007 01:25 PM #11
utol ko marunong niyan pati mga ibang jap food since meron sya jap resto dito hehe, dali lang daw gawin n he gets his supplies from mla. pero la ako alam ha hehe
August 6th, 2007 01:30 PM #12
bb tanungin mo naman, o.. kahit miso soup lang,e.. gust ng daughter ko,e... mahal naman yung sa yoshinoya....
August 6th, 2007 05:58 PM #14
Meron nabibiling mga instant Miso soup, pero may kamahalan din. If I remember it correctly, parang nasa P40-60.00 per pack, serves around 2 lang yun.
August 6th, 2007 06:57 PM #15
mahal....mas mahal pa kaysa sa yoshinoya..
yung miso talaga gagamitin...
August 8th, 2007 02:50 PM #16
napansin ko walang binabanggit na pantimpla(salt/spice) o pampalasa bukod dun sa onion..flavorful naba ung miso on its own?kasi i also see this already prepared na, and i amused na wala na pala itong added pampalasa..
- Aug 2005
- 74
August 10th, 2007 07:34 PM #18Eto subukan mo, the procedure is not so complicated. Bili ka muna ng Dashinonmoto sa mga Japanese grocery, a small bag will cost you mga P20 lang, you can also get the Miso paste and Silken Tofu there. Japanese Tofu is also readily available in most supermarkets. Scallions are the very small native onions which are usually sold with the leaves included. Japanese soy sauce is readily available locally as Kikkoman!
Enjoy
Ingredients
3 Cups Dashi Stock
2 thinly sliced fresh mushrooms (shiitake or white button)
1-1/2 Tablespoons miso paste
1 tablespoon japanese soy sauce
1-1/2 silken tofu – cut into cubes
½ scallions – thinly sliced on the diagonal
1 teaspoon thinly sliced leeks (optional)
BRING the stock to a gentle boil in a saucepan, add the mushrooms and simmer for 3 minutes. MIX together the miso and soy sauce in a small bowl, then add to the hot dashi stock. ADD the tofu. HEAT the soup and, just before it comes to the boil, remove from the heat. POUR the soup into bowls and garnish with the sliced scallions on top to serve.
August 11th, 2007 11:56 AM #19
- Aug 2003
- 9,720
August 11th, 2007 12:22 PM #20naaddict ako sa miso soup ng yoshinoya B)
i read somewhere that dahi made with seaweed is actually "low-grade" dashi; ung "high-grade" kuno is one made with fresh fish. i also saw a tv show mention dried anchovies as the base for dashi.
nag experiment ako a few months ago using seaweed and bonito flakes...medyo bitin ung lasa. try ko gumamit ng dilis next time B)
