Results 1 to 10 of 10
- Feb 2008
- 577
May 15th, 2008 08:48 PM #1hi,
ano po ang nilalagay sa paper gasket para ma-prevent ang possible leaks. alam ko kasi meron nilalagay pa dun bago iassemble ang kahit anong part. ang alam ko rin, correct me if i am wrong, pero "hindi silicon sealant" ang ginagamit.
ano po kaya itong nilalagay dito?
thanks
- Jan 2008
- 4,726
May 15th, 2008 10:45 PM #2i forgot the name of the gasket type used on paper as gasket but i was able to buy one when i was installing an engine water pump WHIZ ang brand.. it looks like RUGBY contact cement but more sticky para siyang gum type.. more effective that using silicon gasket pag silicon kasi ginamit mo at medyo makapal pwede pumasok sa loob ng engine at bumara sa internals
- Jul 2003
- 573
May 15th, 2008 11:20 PM #3It depends on the type of parts to be assembled.
you could use just a plain automotive grease like for carburator
application. Or you may use whiz gasket cement for a more permanent application.
There is also another type of sealant being used to assemble transmission
differentials, forget the brand, it comes in grayish white and have more elastic properties than the whiz gasket cement which dries up hard and brittle.
BANNED BANNED BANNED
- 3,790
May 16th, 2008 12:22 AM #4shellac ang nilalagay ko. pede ring gasket sealer - like the one in tube in this picture below:
http://www.neverseezproducts.com/gaskseal1.jpgLast edited by wildthing; May 16th, 2008 at 12:26 AM.
- Feb 2008
- 577
May 16th, 2008 04:56 PM #5ang gagawin ko actually is carb overhaul. nabaklas ko na. kumpleto nako sa gasket, etc. di ko lang alam kung ano ang dapat na nilalagay sa kanila bago i-turnilyo
- Jan 2008
- 4,726
May 16th, 2008 10:47 PM #6lagay mo na diretso yan paper gasket no need na maglagay ka pa ng silicon gasket...just make sure na pantay at lapat yung carb bago mo higpitan..
ang mga nilalagyan lang ng gasket (contact cement or silicon) eh yung mga parts subject for pressure or contains lubricants like oil pan, water pump..
yung sa carb pwede mo lagyan ng grease or oil pero manipis lang.. tapos tamang higpit lang kasi pag sobra masisira yung paper gasket..
May 18th, 2008 03:11 PM #7
Shellac!!! sino ba ang matanda dito...hehehehe. tapos folder ng school. pukpok pukpok ng handle ng screwdriver para ma exacto ang cut. pero old style na ito and not reliable. kaya bumili nalang kayo ng repair kit hehehehe.
May 19th, 2008 02:04 PM #8
Three Bond yung brand na light grey ang substance. ang pack nya kulay light yellow and konting red.
- Jul 2003
- 2,267
May 19th, 2008 08:17 PM #9three bond din gamit ko. ndi siya tumitigas pag gusto mo alisin pero ok yung seal niya.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 22nd, 2008 08:33 AM #10threebond at most dapat pero in some applications hindi na kelangan lagyan.
Traffic!
