Results 1 to 10 of 25
- Sep 2010
- 131
October 30th, 2010 09:35 PM #1My car is a Toyota Corolla XE 95. I had it overhauled, tuned up, replaced timing belt, replaced the motor in the radiator, modified the carb with a brand new 4k carb, replaced all stuffs with regards to "kalampag", had done everything i know with regards to fuel consumption to save gas, yet it still consumes alot... city driving is 6.5-8km per liter, long drives 7.5-8.5km at the most...
i really am having problems with it... most cars of the same model consumes atleast 10-14km per liter after having read most forums here and other sites... what could be the problem?
Most friends and mechanics i ask suggested to have the carb's jet adjusted to smaller one... but it will sacrifice something, that is, yung hatak daw... but what i am trying to understand is that, why other cars of the same model, even the taxi is fuel efficient than mine? they haven't adjusted their jets yet.. thats what my friends say, some with 2e carb and others with 4k carb... help!!!
October 30th, 2010 09:41 PM #3
How about potential source of "friction" and others?
Dragging brakes?
Wheel alignment?
Wheel bearings?
Does the ac compressor & alternator turn easily?
Are the engine drive belts NOT over tightened?
Is the timing correct and NOT too advanced?
- Sep 2010
- 131
October 30th, 2010 09:51 PM #4i short shift most of the time and i dont rush, i leave early cause i drive slower that in my college days cause i want to save more fuel, i dont even reach 80kph on my daily route, i gave up being a road hog along time ago... it can also be my way of driving, can you suggest more so i can try it?
Brakes - had it checked also
wheel alignment- had it checked too
bearings - had it replaced including the rack and pinion i think thats what it is called and everything that attached to it including the rubber thing, ball joints, and i guess a shock absorber
AC and alternator - i had it adjusted to the very minimal, correct me if i am wrong - the gauge does not reach number 1 when it is idle with and w/o aircon...
timing - (if this is the one concerning timing belts etc) i had it corrected, replaced the belts just before i had it overhauled...
i am really having problems- i had spend that much i can buy another car of the same model (but an ex taxi)
October 30th, 2010 10:54 PM #5
ganyan talaga bro kapag carb....bago umalis, wag ka na masyadong magpainit ng sasakyan.after 5 seconds, sibat na pero wag naman high acceleration....usual lang ba...iwas sa extra load sa compartment.
check mo air filter mo bro, baka low class,o baka madumi.
baka di ok ang timpla ng air-gas mo....baka more on gas,less air...
sa driving, the higher the number na nagshift ka ng gear,less ang gas na maconsume mo....yan e kung di ka galit sa silinyador....
check your tire pressure too.....
THE AUTO SPECIALIST
- Mar 2006
- 607
- Sep 2010
- 131
October 31st, 2010 05:32 PM #7
- Jan 2005
- 445
November 1st, 2010 07:33 PM #8You can Isolate the cause your problems 1 by one, you can start with air conditioning system. Try traveling your normal route with air con off the whole time, if you reach at least 9-10 km per liter then your cooling system's thermostat might be at fault. You may try this then post the results so we cab help you further.
- Jun 2005
- 3,774
November 1st, 2010 08:51 PM #9
- Aug 2008
- 95
November 1st, 2010 09:51 PM #10Try mo mag modify ng air filter... try mo yung cone types na filter. It give better air flow sa carbs. How about yung menor mo? Baka naman masyadong mataas?
Monk-owned R53
