Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Engine and Fuel System Talk Thread, Water/Alcohol injection Turbo Diesel use in The Workshop; You will make more power but use a bit more fluid. It takes a 1/16" allen head wrench to turn ...
Page 25 of 43 FirstFirst ... 1521222324252627282935 ... LastLast
Results 241 to 250 of 427
Like Tree6Likes
Thread: Water/Alcohol injection Turbo Diesel use
  1. #241
    ElgrandClubph FB dvldoc's Avatar
    Join Date
    Dec 2007
    Location
    NORTHERN LUZON / TEXAS
    Default Re: Water/Alcohol injection Turbo Diesel use
    You will make more power but use a bit more fluid. It takes a 1/16" allen head wrench to turn up the pump. Turn it one 1/4 turn clockwise.
    It's that little silver screw on the top of the pump.
  2. #242
    Tsikot Member Rank 1 nelany's Avatar
    Join Date
    Doc will the added power in the pump be beneficial to my use? Is there any rule of the thumb when to increase the pump power to max or use the factory default?
    Thanks
  3. #243
    Join Date
    Dec 2007
    Location
    It's a easy adjustment, try it out see what changes, if you see a improvment leave it at the 250psi setting. The pump is at 200psi out the box.
  4. #244
    Tsikot Member Rank 2 jubs00's Avatar
    Join Date
    Location
    city of smiles
    Hey dvldoc, i'm planning to have a stage 2 installed by Berrima. My rig seldom gets used when i'm not in country, would this have some issues with the pump drying out? Or maybe in other components of the kit? tia
  5. #245
    Join Date
    Dec 2007
    Location
    Quote Originally Posted by jubs00 View Post
    Pump won't dry out. If you want to leave it sitting for long periods of time it's no problem. The kit can pretty much sit as long as your car can. It's only leaving it in cold climates with fluid in the lines that can freeze being a issue.
  6. #246
    Join Date
    This is interesting. Will try this. Thanks for sharing.
  7. #247
    Join Date
    Location
    city of smiles
    Great! thanks doc.
  8. #248
    Forum Moderator ghosthunter's Avatar
    Join Date
    Location
    Metro Manila, Philippines
    MODERATOR'S NOTE:
    All discussion on NUVIMAX and it's technology is moved to it's own discussion thread.
    LINK: http://tsikot.com/forums/engine-fuel...79/index8.html
    Have a nice day.
  9. #249
    Join Date
    Location
    Quote Originally Posted by light2light View Post
    guys, this is not my opinion. water/alcohol inj is considered a hoax in the US(just like ALL fuel savers/engine enhancers). the EPA has wrongfully debunked ALL engine improvements except common rail, turbocharger, efi, direct injection, etc. w/c are now incorporated in modern engines. AFAIMC, kung inaakala niyo na advantageous ito sa mga rigs niyo, by all means, gamitin niyo. personally medyo madugo ito para sa katulad ko na limited ang knowledge sa auto mechanics. kung masaya kayo diyan sa mga accomplishment niyo, dapat ituloy niyo, ika nga, susuportahan ko kayo. tnx
    You are entitled to your opinion.
    Water/Alcohol injection is a proven way to safely increase the power output of a turbocharged diesel engine. This is dyno proven again and again with different vehicles equipped with doc's water/alcohol injection kits.
    I have also used it in a performance tuned gasoline engine with small success in gaining more horsepower.
  10. #250
    Join Date
    May 2012
    Quote: What's there to prove about alcohol injection? The EPA has actually stated that water injection systems allow for better economy, as they prevent detonation and can allow ultra-lean mixtures, but that this often comes at the expense of emissions. A standard alcohol injection kit does not save fuel without retuning, but that's not its purpose. It's not a fuel saver. It's a power adder. It has been proven to add power to forced induction engines for decades, and was even used for a while on stock GM turbocharged cars. Any fuel savings will require retuning to run on alcohol, but such retuning can be dangerous if one ever runs out of alcohol or fluid... which is why GM dropped the system.
    Excerpts from another thread: NUVIMAX Electromagnastatic Fuel/Air Mixing System-reply #98, page 10; can't comment farther as i am not qualified on this scheme. Posted for transparency on Tsikot.com/Forum
Receive Latest Car Engine and Tuning Listings Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Engine and Tuning Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
