Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Sep 2012
    Mga Sirs/Madams,
    Share naman po kayo technique kung paano kayo nakaka iwas sa gas stations na may halong tubig or sand ang kinakarga sa inyo???
    Style ko kasi is rotating sticking to 4 different branches to avoid this... kaso malas ko lang last week after opening the carb nung magloko yung Mazda ito ang nakita sa loob
    1) may deposit ng pinong pinong sand sa loob na halos 1/3 ng kutsarita sa dami
    2) napuno ng tubig idle valve
    Problem now hindi ko ma determine kung sino may kasalanan sa 4 na branch pa konswelo na lang ata ang maka kuha ng coke for every 2,000 fill pero nakaka inis lang talaga sa abala :boom1:
    Jul 2012
    Quote Originally Posted by jodski View Post
    Mga Sirs/Madams,
    Never pa nangyari sakin yan. Hmm. How about a bad looking gas station? Or halos lahat ng jeep dun nagpapagas. Sorry wala ako masyadong idea.
    hindi ba mas advisable na 1 station lang parati magpa pump? para mas mabilis ma-pinpoint kung magka problem
    Mar 2012
    I normally gas up sa isang gas station lang. etong malapit samin.
    so kung magkaproblema man madali ko mapipin point, the station where i don't normally gas up agad ang suspect.
    Iwas ka sa station na madumi yung surroundings, pag malinis yung gas station less prone na napapasukan ng alikabok yung gas pumps nila.
    Jan 2013
    1. Stick to reputable gas stations.
    2. Pick ones with high activity, meaning always ubos ang stock ergo parating bago ang fuel. (So di naman masama kung lahat ng jeep dun nagpapa-gas)
    3. However, do not refuel when you see the tanker at the gas station. Why? When the underground tank has just been refilled, the sediments below are stirred because of the current created by the hose filling the tank making the chance of the said sediments to reach your car's fuel tank.
    4. Do not refuel in gas stations that are prone to flooding as flood water can seep in the underground tanks.
    yun pa lang muna
    Alamin mo kung yun gas station ay nasa bahaing area. Pag nasa bahaibg area yun gas station, mosy likely eh binabaha din sila pag malakas na ang ulan.
    Sent from my GT-N7100 using Tapatalk 2
    Sep 2012
    Madalas kasi sir umikot ako between Lipa City, Alabang, Las Pinas, and Makati area. I just choose stations na malapit kung halos 1/4 na laman ng tank pero specific na yung 4.... Kapag tsumamba nga lang talaga oo
    Feb 2009
    a couple of decades back, gas pumps had a glass bowl or sight glass on the side of the pump cabinet that make you see the fuel going through the pump to your car. now, it is a hit or miss specially if the gas station's underground tanks are still those made of steel and is corroded. the standard in the u.s. as required by the environmental protection agency is that the tanks be made of composite material that would resist developing cracks when there is an earthquake and that they do not corrode allowing contaminants from getting into the fuel likewise the fuel seeping into the ground
    wala na yatang sight glass yung mga pumps ngayon.
    Jul 2006
    You have no way of knowing really. Not unless you get an open pail and have the gas boy fill it up and visually check for impurities. That is if kung papayag yung gas boy. I gas up at the newest station that I can find. That, or I just revert to my suking gas station and have a full tank before I go anywhere.
    Quote Originally Posted by remzam View Post
    yun pa lang muna
    I follow all of these as well (except for num 3 which I was not aware of). I only gas up at 3 stations.
    I have the impression that gas stations with mostly public vehicles as customers might not be as diligent or conscientious than those that serve mostly private vehicles.
    Sep 2012
    Thanks for all your inputs .... isip pa rin ako ng isip pero wala na eh... nadisgrasya na ...
    Kahit nga mag offer sila ng promo na same price ang Nitro+ sa Fuelsave dun pa rin ako stick sa Fuelsave unleaded... gonna take into consideration muna na iwasan kung sino pinaka luma sa branch nila...
    Oct 2011
    Stick to just one(1) gas station preferably sea oil, uni oil or the big three(3).
    Sep 2012
    Shell gas station lang ako palagi sir... kaya nga nagtataka ako bakit ako naka tsamba...
    Petron ata pinakamaganda
    Dec 2003
    Naalala ko yung classmate ko nagpagas somewhere sa pasig may halo daw kaya never na siya nagpagas dun so totoo pala yung may halo.
    Gawang pinoy yun ah? hehe
    Yun barkada ko sa planta ng shell for him Caltex daw pinakamaganda since imported daw yun.
    Mas mataas daw standards sa abroad.
    I think nasa management yan, wala sa brand.
    Kung magandang brand walanghiya naman yung may ari wala din.
    Gaya ni TS shell siya nagpapakarga.
    Jan 2011
    yun pa lang muna
    5. i always refuel in the morning. i read it somewhere that you get more fuel than having it during daytime and evening. as the article explained, cooler temp during the night time makes the fuel denser. pag mainit na daw ang panahon, fuel tends to produce vapor and therefore, the fuel you got when you refuel is mixed with this said vapor. may hangin daw. dont know really if this is really true. wala namang mawawala sa akin kung maniwala ako. i just did it.
    Oct 2008
    [QUOTE=shelu;2135807]5. i always refuel in the morning. i read it somewhere that you get more fuel than having it during daytime and evening. as the article explained, cooler temp during the night time makes the fuel denser. pag mainit na daw ang panahon, fuel tends to produce vapor and therefore, the fuel you got when you refuel is mixed with this said vapor. may hangin daw. dont know really if this is really true. wala namang mawawala sa akin kung maniwala ako. i just did it.[/QUOTE
    AFAIK, kaya mas magandang mag pakarga sa umaga kasi kung malamig ang fuel, expanded pa ito, meaning mas konte ang makakarga sa fuel tank puno na agad so less ang babayaran mo in terms of liters (correct me if I'm wrong). Kung mainit na ang panahon, nag-eevaporate na ito while filling up, meaning as
    fuel comes out from the nozzle, ung nag-evaporate dumaan na sa meter so babayaran mo yun.
Technique paano maka iwas sa gas station na may halong tubig and sand?
