5w-30 has the advantage of better protection during start-up because of its low viscosity under low temperature/morning start-up (mas madaling umakyat yung langis sa mga critical engine parts), better fuel mileage kasi mas maganda ang fluidity niya kapag malamig (mas magaan ikutin ng makina pero during short trips karaniwan siyang mas ramdam yung tipid sa fuel, halos lahat kasi ng oil pare pareho lang ng kapal kapag normal operating temperature assuming same viscosity kahit iba't ibang brand). 1 to 3 cSt (viscosity) is considered negligible when reading the oil's PDS. mas tinitignan kasi ang viscosity during cold start compared sa operating temperature.![]()
is it recommended to use RP HPS 10w40 for a car that has a 155XXX kms mileage? or RP API SAE pa rin?
Panu po pumunta ng speedyfix pag commute lang. Tiga south po kasi ako. Coming from MRT edsa shaw station.
Just bought 4 liters of hps 10w40. Sana ok hehe
Posted via Tsikot Mobile App
Drop off sa Robinson's galleria then cross edsa papunta poea side. Then take a bus or jeep baba Greenhills. Cross Ortigas to Wilson theb grab a shuttle hanggang mini stop. Then make a right to p guevarra its about a 5 minute walk from there
Gudpm po mga Bossing with Bighorn 4jg2 engine, ask lang po sana me ng ilang questions.
1. Gaano kadami po ba gear oil nito,
2, Gaano kadami din po ang ATF
3. Saan po ba nakakabili ng Baldwin Filters at ano po ba Code/Number ng fuel filter para sa 4jg2
Planning to change gear oil at ATF po this March with RP/Mobil lubricants (first time) since nabili yung Bighorn.
Reply With Quote Reply With Quote
Sir speedyfix magkano po pa change ng atf ng Nissan Exalta granduer using royal purple atf? Yung all in price po, thanks![]()
Rp atf is 890/quart x3 and labor to replace it is 400.
5W30 srp is 600/quart
