Page 52 of 195 FirstFirst ... 24248495051525354555662102152 ... LastLast
Results 1,021 to 1,040 of 3899
    #1021
    Just got my mobil 1 turbo diesel truck, now 450 *trading post , 2nd floor of cash and carry
    Quote Originally Posted by zix888 View Post
    P10 price hike ah. hehe
    Jun 2005
    #1023
    hey doc, do you know the technical specs of mobil1000? it readily available is it a good dino juice?
    #1024
    Yup you are correct! I saw some mobil 1 15w-50 fully syn, is it also good? In case these tdt ran out?
    Dec 2007
    #1025
    Quote Originally Posted by sirkosero View Post
    It's no better and no worse than a oil of the same API rating that is group II oil.
    Mobil Super 1000
    Here is a good listing I found which breaks down oils brands with what group of oil they are ie. Group II, III, IV or V.
    Auto-Rx (Philippines) | About Oil
    Dec 2007
    #1026
    It's no better and no worse than a Group II oil with the same API rating. Not a big fan of Group II as it has a lower TBN and will have to be replaced sooner. You would be better off with a group III oil.
    Here's a good listing of some oils there with the groups types.
    Mobil 1 15W-50 Advanced Full Synthetic Motor Oil
    API rated only as CF plus its rated SN which is not ideal for diesel per se, maybe better off using Mobil Delvac MX 15w40 or Mobil Delvac 1 5w40 instead if meron sila sa Trading post.
    MOBIL DELVAC 1 5W-40
    Viscosity, ASTM D 445
    cSt * 40ºC 102
    cSt * 100ºC 14.8
    Viscosity Index, ASTM D 2270 151
    Sulfated Ash, wt%, ASTM D 874 1.35
    Total Base #, mg KOH/g, ASTM D 2896 12
    Pour Point, ºC, ASTM D 97 -45
    Flash Point, ºC, ASTM D 92 226
    Density * 15ºC kg/l, ASTM D 4052 0.854
    Moreso from 2 threads i've read they stopped making this already.
    mobil 1 synthetic 15w 50 silver cap auto oil - Bob Is The Oil Guy
    May 2009
    #1028
    ^in contrary, API CF is rated for use with diesel fuels having greater than 0.5% ppm sulfur. higher than CF are those oils for use with fuels lesser than 0.5% ppm sulfur. not that i'm against those high ratings with regards to API ratings (actually, i've been a user of CI-4 delo gold multigrade). what i'm saying is if you use API rated oils higher than CF, you have to change your oil more often than when you are using CF. by the way, i dropped my pan for the first time and i'm really surprised with the internal condition. no sticky gunk on the pan as well as on the sides of the block. well, thanks to delo of course. found only bits of silicone sealant at the pump screen and on the pan as well. i filled her up again with valvoline CF-4 15w-40.
    #1029
    cSt * 40ºC 102
    cSt * 100ºC 14.8
    Alright thanks for the info sir Ry_Tower
    Jun 2009
    #1030
    Sir bought mine at Shopper's Delight, 2nd floor also at Cash&Carry, 440 per quart and yes madami sila stocks ng engine oils there like Top1 and different grades of Mobil 1's, all made in USA
    Quote Originally Posted by miked View Post
    As you said, higher rated diesel oil is good enough for 5,000kms COI.
    #1032
    As promised, here is my bd28(5000kms , oil on its 10000kms)
    Dec 2007
    #1033
    Filter held up like a champ, Oil is still pretty black but that's mainly from soot, The lower quality fuel there makes it hard to keep that from happening besides soot particles are down in the sub 10 micron range.
    What are you using to cut your filters, that's a pretty clean cut.
    #1034
    So should i use these filters for 10000kms? Or just 5000kms? I just cut those filters manually sir(saw). Thanks so much, we really need your expertise on this
    #1035
    According to dvldoc, you can use these filter for up to 12,000 KMs per oil change using a good quality oil. So you change every 12,000 KMs together with your oil, am I correct Doc?
    #1036
    Quote Originally Posted by HardCharger View Post
    Yup that's what doc mentioned before. I just wanted to show him the actual condition of the filter after 5000kms, because the oil is really black after 5000kms on these engines(4d56)
    Dec 2007
    #1037
    The oil being that black is not a big deal, soot particles suspended in oil can be as small as 5 microns, Even with the synthetic media filters engine like our 5.9 Cummins diesel turns black the day after you change the oil. Not much you can do about it. But it does not have a detroment to the oils service life. Some engines are just sooty which is a combination of not the best fuel and that's it's a diesel engine.
    That filter is in rock solid condition, that media has a long way to go before it stops filtering, Remember these fitlers are designed for extended oil change intervals over factory oil filters.
    If your changing them out every 5000km your just throwing away money. And for the bypass section the dirtier they get the better they filter. Changing them out early reduces this effect. In reality the bypass section is good until it stops flowing oil these filters hold about 4 times more dirt than most OEM filters so a 10000km to 12000km oil and filter change interval is advisable
    But if you really want to know how your oil is doing get it tested. Found this link for a long time ago I don't know is this CAT dealer is still around but it might be worth a look.
    http://tsikot.com/forums/other-troub...sis-lab-14481/
    And here is a company that also does testing.
    CRE Laboratory - Oil Analysis
    PTT Philippines Corporation
    #1038
    Alright doc, this will spare me from the hassle of topping up * 5000kms, plus save me a lot(filters and oil). Learned a lot from you doc, thanks. Oem filter cost around p900+ and needs to be replaced * 5000kms, while baldwin is just p765 to last upto 10000kms, this is really great!!!
    Jun 2007
    #1039
    sir zix, what oil are you using again? TIA
    #1040
    Yung nasa image sir turbo xp ng mitsu 15w-50 fully syn. Yung inilagay ko ngayon is mobil 1 TDT 5w-40 fully syn
Remote bypass oil filtration
