Page 34 of 67 FirstFirst ... 2430313233343536373844 ... LastLast
Results 661 to 680 of 3899
    Jan 2012
    Had my change oil yesterday. Here's the oil filter element Toyota uses now for the 1ZR engine on the Gen 10.5 Altis.
    This piece of origami cost P318!!!
    The mechanic dropped the used filter into the can before i could get i. I'll take a shot of the used filter during my next service stop.
    so boss parang refill lang sya?
    ^ Yep. And Toyota uses a special tool to remove the canister so when you have service done elsewhere, the mechanic should know how to properly unscrew it.
    I hope better aftermarket elements will become available just as well. The o-ring (seen next to the filter) is also replaced every oil change.
    Jan 2012
    that kinda sucks. limits you from using other after market filters like baldwin or FG.
    You are stuck with Toyota OEM for now I guess till there are after market options.
    Sep 2010
    Hello again folks, * dvldoc, earlier in this thread you mentioned that not all oem filters are crappy. How do mazda oil filters compare to fleetguard or baldwin's?
    Dec 2007
    they are fine for standard oil change intervals, most oem filters will not be any better than 40 to 30 microns absolutE (98.6%) they will also hold about 3 times less dirt than a fleet service filter.
    This is a good layman's term explanation on OEM vs. fleet filters.
    Dec 2007
    I still have a few of the LF3564 left, pm is u want them.
    May 2012
    Just called Volmax a while ago. BD28 and BD7028 to be available on September pa! hintay hintay..
    Quote Originally Posted by Arj_11 View Post
    Huwag ka maniwala. Last year pa nila yan sinasabi. Every month na-move.
    May 2012
    Nakakainis na nga eh, oh well. Sana naman before end of the year may dumating na. Pag may dumating, sana we can limit ourselves to 2 per item para naman yung ibang gusto, makakuha din. I guess 2 filters will last us 20K which is enough for 1 year worth of travel.
    Meron naman si doc na binebenta na mas maganda pa sa BD28 so meron pang magagamit na iba.
    Sep 2004
    I agree
    Sent from my iPad using Tapatalk HD
    May 2012
    *sir dvldoc
    You said that wix oil filters are good. Are there any problems with the quality of wix oil filters produced here? I'm just curious because almost everyone here are looking for baldwin. I haven't read the whole thread yet but our car is due for change oil next week so I need some info. My place is too far from volmax but if the oil filter of baldwin has a significant advantage over the wix filter then I'll opt for the baldwin. I'm a bit wary of the fleetguard sold here right now so that's out of the question.
    And one more thing, our car usually takes a year to get to only 4-5k km - short trips mostly. So, are mineral oil(mobil) + baldwin/wix filter good for a year/5,000km or do I really need to get the mobil1 fully synthetic. How about semi-synthetic?
    Thanks in advance doc.
    Dec 2007
    Wix is what u would call a heavy duty filter, they are very well constucted. there should not be any produced here, sold here yes but made.
    Give me a PM i bet i have your filter. * * 5000k Intervals a good mineral oil or semi synthetic is fine.
    Jan 2012
    hey doc, whats the next best filter for the 4d56 engines (pajero) besides the BD28 or LF3564? Which you currently on stock. my friends inquiring about the LF3564 found it on the steep side. hehehe!
    thanks in advance.
    Dec 2007
    You can go with the bosch version it says its good for 10000k
    Guys open ba ang Volmax ng Sundays? Thanks.
    Nope. Monday to saturday lang.
    dvldoc,
    i tried looking online for a bypass system for the M26x1.5 thread size, it seems that the manufacturers do not make a kit of this size.
    Aug 2012
    Guys,
    Need your inputs on the pros and cons of using 5W50 FS oil (gasoline engine) in our climate ........ TIA
Remote bypass oil filtration
