Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Engine and Fuel System Talk Thread, Remote bypass oil filtration in The Workshop; Originally Posted by crazy_boy sir, just wondering, how do you pour the oil? mejo hassle yata sa pail. The lid ...
Page 244 of 333 FirstFirst ... 144194234240241242243244245246247248254294 ... LastLast
Results 2,431 to 2,440 of 3324
Like Tree117Likes
Thread: Remote bypass oil filtration
  1. #2431
    G01
    G01 is online now
    Tsikot Member Rank 2 G01's Avatar
    Join Date
    Jan 2003
    Location
    Benguet Province
    Default Re: Remote bypass oil filtration
    The lid has a small opening that is covered with a threaded cap.
  2. #2432
    Driven blue_gambit's Avatar
    Join Date
    Location
    Malabon Seaty
    Quote Originally Posted by G01 View Post
    what filter do you use? baldwin?
  3. #2433
    BANNED BANNED...NOT! number001's Avatar
    Join Date
    May 2005
    Quote Originally Posted by Ry_Tower
    Delo 400 is better but the price difference and the fact that you don't change oil more than 10,000kms mean that you're current oil is sufficient to provide all the protection you need.
    Based on specs alone, DELO 400 is looking better.
    VALVOLINE ALL FLEET PREMIUM
    Performance levels / Approvals
    API CI-4/SL
    ACEA 04- E2/B3/A2
    ACEA 02- E2
    MB 228.1/ MB228.3 / MB 229.1
    Mack EO-M Premium Plus
    Volvo VDS 3
    Caterpillar ECF-1
    ZF TE-ML 07C/04C, Allison C4
    MAN 271
    Cummins CES 20071/ 20076 / 20078
    Typical Characteristics
    Appearance Bright & Clear
    SAE Grade 15W40
    Kinematic Viscosity, cSt @ 100oC 14.91
    Viscosity Index 135
    TBN, mg KOH/g 9.5
    Flash Point, COC, oC 210
    Pour Point, oC, Max. -30
    CCS @ -20 oC, cP, Max. 6700
    http://www.valvolineasia.com/Upload/...et_Premium.pdf
    Delo 400 Multigrade
    PERFORMANCE CHARACTERISTICS
    • API Cl-4 PLUS, Cl-4, CH-4
    • API SL, SJ
    • ACEA E7-08, E5-02, E3-96.
    • JASO DH-1
    • EMA Global DHD-1
    • Caterpillar ECF-2, ECF-1-a
    • Cummins CES 20078, 20077
    • DDC 93K214
    • Mack EO-N Premium Plus 03
    • Mercedes-Benz 228.3
    • Volvo VDS-3
    Planned Approvals
    • MAN M 3275
    • ZF TE-ML 04C, 07C
    • MTU Category 1 and 2
    • Renault RLD-2
    Meets the Requirements of
    • API CG-4, CF-4, CF, CD
    • Cummins CES 20076, 20072
    • Mack EO-M Plus, EO-M
    KEY PROPERTIES
    SAE Grade: 15W-40
    Density at 15°C, kg/L - 0.886
    Base No., D2896, mg KOH/g - 12.2
    Base No., D4739, mg KOH/g - 10.0
    Sulfated Ash, %m - 1.4
    Flash Point °C - 230
    Pour Point °C (-33)
    Viscosity, cSt at 40°C - 125
    Viscosity, cst at 100°C - 15.1
    Viscosity Index - 125
    Zinc, %m - 0.15
    http://www.caltex.com.au/productsand...n.aspx?ID=1639
  4. #2434
    Tsikot Member seymorebutts's Avatar
    Join Date
    Location
    N.P.A.
    i just had my oil changed this morning using delo 400 from previous petron trekker, so far less vibration and noise pa lang nararamdaman ko, will keep monitoring
  5. #2435
    Tsikot Member Rank 5 Ry_Tower's Avatar
    Join Date
    Location
    The Last Frontier
    Delo Gold Ultra (which really good as well) kasi katapat niyang Valvoline all fleet premium. But at P183.33 nga kasi pail yung binibili niya, mas mura siya ng mga P20-30.00
  6. #2436
    ElgrandClubph FB dvldoc's Avatar
    Join Date
    Dec 2007
    Location
    NORTHERN LUZON / TEXAS
    You might want to check with berrimma diessel for some of my fine filters soon, sorry no 4m40 filters in stock yet.
  7. #2437
    Join Date
    Mar 2012
    The Caterpillar 307B excavator uses the 4M40 engine. The CAT dealer or heavy equipment parts stores might have the oil filter for this engine.
  8. #2438
    Join Date
    Location
    The Last Frontier
    Quote Originally Posted by Rocko24 View Post
    It's the 4m40E1 which I think has a different thread.
    WIX FILTER 51798 CASE OF 6 Caterpillar Mitsubishi Isuzu | eBay
    "PARTS DETAIL
    Principal Application: Caterpillar, Detroit Diesel Engines, Hitachi Excavators, Isuzu H.D. Trucks, Mitsubishi Trucks
    Style: Spin-On Lube Filter
    Service: Lube
    Type: Full Flow
    Media: Paper
    Height: 5.968
    Outer Diameter Top: 4.282
    Outer Diameter Bottom: Closed
    Thread Size: 1 1/8-16
    By-Pass Valve Setting-PSI: None
    Beta Ratio: 2/20=24/45
    Burst Pressure-PSI: 420
    Max Flow Rate: 18-20 GPM
    Nominal Micron Rating: 32
    WIX 51675/51067 yung puwede sa 4M40 eh.
    PARTS DETAIL: Wix 51675
    Principal Application: Mitsubishi Trucks
    Service: Lube
    Type: Full Flow/By-Pass
    Media: Paper
    Height: 5.981
    Thread Size: 26X1.5 MM
    By-Pass Valve Setting-PSI: 13-16
    Nominal Micron Rating: 6
    Ganda nga ng micron rating nitong Wix 51675 eh, biruin mo, 6. So 50% efficient at 6 microns. Parang original LF3564.
  9. #2439
    Tsikot Member Rank 5 crazy_boy's Avatar
    Join Date
    i think there are other resellers of baldwin in caloocan. just this morning, i saw a guy in a motorcycle along c-3 road. and there is a baldwin logo printed on his shirt. wasnt able to get the company name on the front of his shirt though. he's wearing a blue shirt.
  10. #2440
    Join Date
    Location
    Malabon Seaty
    Hi doc just wanna ask if baldwin b1446 is the correct filter for my isuzu 4JA1 n/a engine? i'm going baldwin all the way... hehehe
Receive Latest Car Engine and Tuning Listings Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Engine and Tuning Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
