Sir, na try moba kalugin ang FG filter kung madidislocate ang spring? I guess same batch tayo ng old-stock filter from pacer since ive noticed the rust. When i opened mine, the can is full of rust then the spring is weak (maybe due to age). Hope hindi ma tetanus ang engine mo..hehe Sabagay microglass naman yan, mafifilter nya yung sarili nyang rust.
Hi, I really am not very experienced regarding wear metal deposits sa engine but I do know that if you can see them with your bare eyes, there is something horribly wrong with the engine already. Has there been any documented case like this that has been posted in this thread? I'm quite intrigued.
Manual requires the following:
2TR-FE (2.7 li)
w/ Toyota OEM filter = 5.6 li
w/o filter = 5.3 li
The Toyota OEM doesn't look like it can hold 300 ml.
I put in 6 quarts = 5.676 li. (946ml = 1 US Quart).
I think its about right since the Fleetguard probably holds 430 ml.
(Toyota dealer will easily dump 6 liters but its less than that since their mechanics don't drain the oil cans to the last drops, unlike what I do with mine).
http://cumminsfiltration.com/pdfs/pr...es/MB10046.pdf
Understanding Engine Oil Contamination and Filtration.
I believe good quality oil (such as CH-4 or CI-4 for diesel) should turn very dark brown after 5,000 kms (good engine cleaning properties) without breaking down (high TBN, Flashpoint, etc.) but it should be paired with a good oil filter (high efficiency rating) to reach atleast 10,000 kms easy.
Doc, is it safe to run ZIC UP 10w-40 upto 10,000 kms on a Mitsubishi Triton/Strada 4d56 engine?
Currently using the Asian-made Fleetguard LF3564 and it seems to be doing a good job at 4,200 kms (oil being very dark brown and not grainy to the touch). The oil actually wipes clean from the fingers with just a pass from a tissue paper and is still very fluid despite the dark color.
Bg, magkano kuha mo sa bd28? Swerte mo hehe
P840 cb, mas mahal yata compared ke volmax, pero ayus lang di naman ako pinahirapan mag park at sa trapik... hehehe![]()
Mga sirs, where can I get BT223 other than Volmax and how much? Tamad na ko magbackread. TIA.
By the way, I got all my filters in except for the 4M40 ones of course, You'll see them in the classifieds soon, I have to sort them all and put them up, it's like 600 plus of them,![]()
Mga boss alam ko medyo out of topic ako. Pero kasi napansin ko parang umingay lalo engine ng MS ko after my 1k PMS eh i used mineral oil galing sa casa. Pati oem oil filter. Then i fill my gas sa seaoil. I was wondering may kinalaman kaya ito sa langis na ginamit? Balak ko sa 5k pms ko eh sa labas na mga service center ko na pagawa para makapili ako magandang oil and filter.
