Page 10 of 67 FirstFirst ... 678910111213142060 ... LastLast
Results 181 to 200 of 3899
    Sep 2010
    Sir! any significant changes on your engine after shifting to Mobil Delvac MX? Does it accelarates faster or engine becomes more quiet?
    Sir Retz, kilala talaga ang 4JA1 or isuzu engines na malayo ka pa, the gate is opened by the time you reach it. hehehe
    beep beep! pasensya na po sa mga kapatid na naka isuzu... hehehe
    i don't think anything can be done anymore to lower the dB noise of isuzus. that's why many recommend to set up a GOOOD & LOOOUUUD sound system instead.
    :laughbounce:
    seriously, i can't tell any major difference at the moment except for tumaas ang idling ko. probably as i said lumuwag luwag ang hinga ng makina
    she's still under observation 'cause i replaced my water pump due to a loose bearing na after our office staff borrowed my ride and went to La Union and Baguio. They returned it to me and i noticed my clutch fan was wobbling wildly! and the engine was vibrating abnormally. wala naman akong magawa, hindi ko naman pwede sermonan yung mga humiram. that's life..
    ^ have you tried Volmax already?
    Sep 2010
    haven't tried yet. aside from kailangan sadyain ang lugar, i believe everyone is still waiting for the latest shipment to arrive.
    it seems they've wised up (volmax), increasing the SRP of the filters due to insistent forum demands.
    also, majority here have mitsubishi, toyota & honda rides.
    the B104 is for my 4JA1, cross for the (BIG size) VIC C-503 oil filter.
    Dec 2007
    Quote Originally Posted by SpeedDzel View Post
    You can also go with the B1446
    Sep 2010
    Hi dvldoc!
    the Baldwin B1446 is the cross for the Vic C-512 (small size), used by crosswinds with M/T and non Turbo models.
    my 2003 XUV is a 4JA1(NA, L) variant with A/T, Turbocharger that comes with the BIG size filter.
    if ever, will the small type filter not affect or hinder performance of this kind of engine set up/configuration?
    This is what i've gathered so far.. My OEM# 8-94167-399-0
    crosses with the ff;
    ITSUMO 8-94167-399-0
    JSAKURA C-503
    Baldwin B109
    Fleetgrd LF3433
    Donaldson P905002
    MANN W92180
    WIX 51386
    BOSCH OM 037 (aka OF 503)
    FRAM PH4731
    VIC C-503
    whilst the small type filter (not designated for my ride)
    OEM# 8-94430-983-0
    Baldwin B1446
    Fleetgrd LF3528
    Fleetgrd LF3786
    Wix 51523?
    Donaldsn P502039
    Vic C-512
    Dec 2007
    Hi dvldoc!
    JSAKURA C-503
    Baldwin B109
    Fleetgrd LF3433
    Donaldson P905002
    MANN W92180
    WIX 51386
    FRAM PH4731
    VIC C-503
    OEM# 8-94430-983-0
    Baldwin B1446
    Fleetgrd LF3528
    Fleetgrd LF3786
    Wix 51523?
    Donaldsn P502039
    Vic C-512
    Ever hear the phrase size does not matter, The Baldwin B1446 has 3 times the dirt holding capacity over the Vic, They also will have more pleats and 3 times the efficiency rating. So going with the larger filter will make little difference in your oil change intervals if your not going over 12000klm per oil change.
    The B106 holds 20.81 grams
    The B1446 holds 18.04 grams (has no anti drainback valve) which is not needed if a filter is not mounted upside down.
    The flow rating are also close the smaller has 25gpm while the larger has 22gpm so the smaller one actually flows better.
    You can stray from OEM recommendations quite a bit, If you do a little back reading you'll see how I explain this. Both these filters will work on your vehicle, having a turbo makes no difference, especially one that only makes 4hp over the stock engine, People keep the same filters when adding a turbo to their current engine.
    As long as the sizes is close to the same, the bypass valve is close to the same, in this case they are identical at 20psi you are good to go.
    Don't limit yourself with options by only going with the OEM number.
    tumaas napo ba price ng bd28? hehe magkano napo?
    Sep 2010
    Quote Originally Posted by AC View Post
    mukang may balak na ata sila magtaas based on sir troyadam's post a few pages back...
    Quote Originally Posted by troyadam View Post
    They might increase the price, When their shipment comes sabi ng volmax. Lalo na in demand na ang filter. I try to call the fleetguard sa new manila baka may LF3564 the same as Bd28.
    sa alam ko po mas mataas na ang minimum sa china kesa saatin..
    mura lang po yata kuryente nila and efficient po mga system nila
    They also have problem wilth the supply of electricity. Their plant have sched shutdown on a weekly basis especially on summer.
    Dec 2007
    I plan on doing it as a hobby to keep busy, I retire from the US Navy after 20 years next month. I'll be in the Philippines 60% of the time.
    Dec 2007
    Tell them to read this thread so they can see the demand for it.
    the only bad thing with dealers/distributors knowing that there is a market for their items is that they will jack the price as soon as they can. just like what the previous poster said when Volmax commented that they might increase the price. i hope they dont since the forex rate is already getting better at 42.50 = 1. i dont see any reason why they should increase price since it will be cheaper for them to import it..
    Jul 2011
    any updates on Foton vehicles with Cummings and FG filters?
    Are the dealers/casa will sell it and what will be the size of oil filter on those Foton with cumming's engine?
    Cause I don't see any new pick up on their showroom aside from Blizzard pick-up.
    Jul 2011
    i'm beginning to envy you guys you can put a better oil filter and oil on your rides but my innova was declined by casa to even bring my own oil due to warranty voiding it...
    Oct 2011
    Quote Originally Posted by MrQ5 View Post
    saan casa yan sir?
    Dec 2007
    That is such a scam these dealerships run, No other country I know of does this. You should ask to see that in writing about the oil voiding your warranty. It's basically a form of blackmale.
    Exactly. It's something i noticed with Toyota and they'll scare you by saying that your warranty would be void. When i used to go to Nissan for servicing before, they never had any qualms about me bringing in my own oil and parts. I just stuck to the OEM oil filter while the car was under warranty and they even did some warranty repairs a few months after my warranty lapsed. With my Corolla now, after the 10,000kms service, i'm going to be using my own oils and filters already.
    most of the toyota dealerships doesnt allow bring of own oil/filter. while most of mitsubishi dealerships do allow.
    Sep 2010
    ..reading between the lines, it's another way of saying
    "if we can't capitalize & profit from you, we'll VOID your warranty!"
Remote bypass oil filtration
