Results 3,661 to 3,670 of 3897
- Sep 2013
- 630
April 3rd, 2014 10:35 PM #3661^
Ok sige interested din ako kung ano effect. Nabasa ko kasi dati kay dvldoc na around 6 lang daw allowance pag lalagpas sa bypass valve.
Tataka ako sa b178 bakit mas mura sa b33 na pang corolla talaga. Eh ang liit ng b33 pero nung nagemail ako sa baldwin ang ganda pala micron filtration rating b33.
April 4th, 2014 06:53 AM #3662
And B178 is almost twice the capacity of B33, kung hindi ma-clog ang maliit sa one oci, ang mas malaki pa kaya... That's why, no worries for me.
I also sent email to Baldwin, sabi, if you don't want to worry, use one of the same bpv setting as OEM, 14 psid, but also insinuate, you can't go wrong with the high debris carrying capacity of B143 and B178 with excellent filter media, unless you have a very dirty engine.
Rule of thumb sa OP, 10psi every 1k rpm. Kung 14psi ang bpv ng oil filter, cruising at 2k rpm, kung maliit filter used at malapit na end of oci, sa sudden acceleration, say, umabot 3k rpm, maybe the bpv will engage, lusot unfiltered oil.
Posted via Tsikot Mobile App
- Sep 2013
- 630
April 4th, 2014 04:29 PM #3663Yung b243 ok din 8psi bypass valve.
Meron pa isa mahaba 14psi by pass valve nalimutan ko code.
April 4th, 2014 05:04 PM #3664
Preferred ko Baldwin oil filters with 20 psid and above na bpv setting, 80 mm casing outside diameter, 65mm-70mm outside diameter ng gasket, kahit 130mm long, will fit my 4AFE.
Sent from my HTC Explorer A310e using Tsikot Forums mobile app
April 21st, 2014 10:35 AM #3665
B1402 - Php 360 last year (dont know this year).
Alternative
Bosch OF415 - Php 150 (amazon)
April 21st, 2014 10:59 AM #3666
- Aug 2013
- 475
April 21st, 2014 04:19 PM #3667
- Sep 2013
- 630
April 21st, 2014 04:31 PM #3668Ano code yan bosch na 200 pesos?
Yung b1402 nasa 350 pesos yan sa banawe seller.
- Aug 2013
- 475
April 21st, 2014 08:22 PM #3669
April 22nd, 2014 10:32 AM #3670
It was 350 back in 2012. If I'm not mistaken, it was 320 before that.
As for the OF415, I did not get to check its country of origin bec. I just asked the messenger to inquire.
Not all Bosch are made in Korea. Some are also made in indonesia ie. OK 064
Pls PM me contacts of your banawe supplier. Thanks!
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
