Results 31 to 40 of 52
May 3rd, 2008 11:46 PM #31
Yes it does. The outlet of your exhaust system has an effect on your power. I just don't know what's ideal for your set-up.
May 4th, 2008 05:00 PM #32
ay ganun ba, so problem nga ung sa midpipes, try ko icheck with the shops I have called up kung meron silang 1 and 3/4 na pipings...
Add ko na rin, Feedbacks from HP racing? have called them up also, medyo 2x the price ng mga headers sa other aftermarket shops...
May 4th, 2008 06:10 PM #34
Ask ko lang po sir nicky!
iseset-up ko po kasi civic fd ko ng turbo to gain hp!
my question will be ano pa ba iba kong pedeng gawin to gain hp!
Camgear? port n polish? tnx
May 4th, 2008 08:59 PM #35
Turbo is the easiest way. The 1.8 really isn't that receptive to naturally aspirated mods... it's already pretty strong for its size.
May 5th, 2008 01:33 PM #36
*niky,
11-12k daw , stainless - mandrell bent, custom daw kc, kasi ggawan pa daw ng design..
vs.
sa Mufflerland nahalf the price ng HP,
May 16th, 2008 09:48 AM #37
Update:
have finalized to purchase the I/H/E upgrade..:
Simota tube + K&N Uni filter
Mufflerland Mandrel Bent 4-2-1 (1.75")
FreeFlow muff (1.75")
Additional Questions are: after installing the IHE
1. would a Change from stock to an Aftermarket Adjustable Cam Gear give an effect to the cars performance?? have heard, llkas daw hatak pag nsa Slick or Track road
2. DO I need to make a General Tune Up and Reset my ECU?
Thanks sa mga nag replies, dami ko ng insights..
May 17th, 2008 11:43 AM #38
Go for a 2" muffler nalang. 1.75" may be too small.
Cam Gears... so-so... performance cams first, then cam gears... or better if you can get them bundled. I don't really know on your engine... and it's not a cost effective mod. Not as cost effective as, for example, buying a V-AFC (kahit secondhand) and having the car dyno-tuned.
After IHE, medyo mahal ang mga mods for the gains they give. The only expensive mod that's "sulit" is rechipping or programming. Everything else is a lot of moolah for just a few ponies.
May 21st, 2008 11:23 AM #39
san ba maganda? IM choosing whether:
Nodalos or MufflerLand, medyo may difference sila,
Nodalos - Non-Mandrel
Muffler - Mandrel
may iba pa bang suggested?
May 21st, 2008 11:23 AM #40
Muffler - Mandrel
Then
