Results 1 to 10 of 14
- Jul 2010
- 28
July 28th, 2010 12:00 PM #1To all tsikoteros magandang umaga po.
I have some trouble again and again po sa engine ko. it is a owner type jeep with a 4K engine and with a 4 speed tranny.last saturday we travel sa dau pampanga using NLEX highway....since i was on the 4th gear biglang namatay ung makina.kapag nagstart ako umiikot bcoz of the battery but hindi tumutuloy.then nakakita ako ng mekaniko at ginawa nya.then adjustment sa ignition for timing again..nagstart xa but after non tumakbo kami namatay na naman ung makina.sana po kung merong pong kayong magaling na mekaniko ragarding dito near po ako sa welcome rotonda.and share naman po ung mga ideas nyo base sa nobela ko...more power!
July 28th, 2010 12:25 PM #2
[SIZE="4"]REMINDER: do not post messages with SMS/TXT shortcut format.
Read the rules.
Ignorance of the rules is NOT an excuse.
Repeated offenses will lead to banning.
Have a nice day.[/SIZE]
July 28th, 2010 12:30 PM #3
palagay ko nagooverheat ka ng hindi mo alam... sira ba temp gauge mo?
o kaya barado carburador mo.
o kaya talagang wasak na makina mo pag umikot ng mabilis nawawala na sa tamang adjustments.
July 28th, 2010 12:38 PM #4
o sira na ignition coil. pag iminit nawawalan ng output. pag lumamig ayus na naman.
- Jan 2005
- 445
July 28th, 2010 01:38 PM #5It could be a lot of things.
It could be the coil - kaya lang sabi mo nasa 4th gear ka na at mataas ang rpm mo na. Kapag on idle lang lumalamabas ung problema sa coil.
Most probably eh fuel related yan. nag palit ka na ba fuel filter? Baba tanke then linis carb? Nasa ayos kaya adjustment mo ng float? Malakas pa kaya ang fuel pump mo?
Pag mahina kasi fuel pump eh madalas sa high speed mo mararamdaman.
Pede rin loose compression kung lagi ka namamatayan ng spark plugs.
- Jan 2005
- 445
July 28th, 2010 01:43 PM #6It could be a lot of things.
- Jul 2007
- 27
July 28th, 2010 02:52 PM #7Palagay ko sir overheating nang di mo napapansin yan, sira po ba yung fan niyo to dissipate the heat and your temp gauge???
Sir if you need a very good mekaniko po na mapagkakatiwalaan just pm me po I will refer you to my mechanic trusted ko na po ito and sure ball po kayo sa kanya... Just pm me po.
Thanks.
- Nov 2006
- 201
July 29th, 2010 04:57 PM #9+1 din sa coil. maski high speed nagiinit ang coil. sakit yan ng 4k na makina, di rin pwede mabasa. palitan mo na lang ng sealed na igniter. di porke luma car di na pwede ibyahe sa malayo. kalokohan yan, owner ko nga 1972 ko pa nabili JIffy with 2R engine binabyahe ko pa sa nueva vizcaya at nakakasabay pa sa car ko...
- Sep 2009
- 35
July 30th, 2010 08:34 PM #10ganyan din sa pinsan kong owner jeep 4k engine . daming pinalitan fuel pump, sparkplug, caburador, distributor cap at sabay change oil.. tamakbo din ng maganda.. after ng ilang oras namatay pa rin.. nang tiningnan parang natunaw raw yung contact point ng distributor cap kaya inayos ulit...ayun tumakbo na naman... still under observation pa rin ngaun..
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
