Results 1 to 6 of 6
July 15th, 2008 08:50 AM #1
Hello friends.
How many liters (during a normal engine oil change) would a 1998 Nissan Cefiro with a VQ20DE engine (2.0 liter V6) require? Lost the owner's handbook - was able to search on the web that a VQ30DE requires 4 liters, would this be the same?
And while we're on the subject of lost owner's handbooks - how many liters of Automatic Transmission Fluid is required during a normal ATF change? On a similar model Maxima with a VQ30DE, it's 9.4 liters. I understand that not all of this though is emptied out during a normal fluid change. What fluid type is recommended?
Shouldn't have lost that handbook...thanks!
July 16th, 2008 09:30 AM #2
hi! my vq20 requires about 3.75 L of engine oil. the manual recommends 5w30 (energy conserving oil).
July 17th, 2008 08:11 AM #3
Thanks much bro!
Would you have any idea about the automatic tranny fluid - how much is needed during a fluid change and what type is recommended?
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 20th, 2008 11:00 AM #44 lits is more than enough. eithe a 5w30 or 10w30 works fine.
most dex 3 atfs will work without problems. you will need 3-4 lits if you do a regular drain refill. mga 12-15 lits if you use transtech.
- Nov 2003
- 3,849
Methinks the Battle of Carthage scene in Russel Crowe's Gladiator (yr. 2000) is a homage to that...
Traffic!
