Ano ba meron sa oil extreme sir?
for scientific facts i will recommend to click the link and to know more about oil extreme and to know about the product OIL EXTREME CONCENTRATE: MOTOR OIL: BETTER THAN SYNTHETIC MOTOR OIL ...
sir a revolutionary new calcium carbonate technology.. http://oilextreme.com/tech1.html
I was hoping meh MSDS or PDS... anecdotal lang lahat info...
i think hindi possible ma-transform ang isang mineral oil to fully synthetic oil just by adding something to an already existing chemistry...
where you drilled the base oil, how you refine and process it, will determine if FS o mineral siya...
how so.........?yung mga normal oil ginagawa nyang synthetic just by adding oil extreme...
Oil Extreme™ "Better Than Synthetic" Motor Oil is specially formulated using the new Group III, very highly refined, hydrocracked and catalytic dewaxed petroleum base oil. This "white water" as it is called is so pure that it is crystal clear. It is processed in special plants built by several major oil companies, under high temperatures and pressures to remove all the sulfur, nitrogen and oxygen compounds that normal solvent extraction processes can't remove.
By eliminating these harmful compounds in the base oil it is possible to formulate engine oils with oxidation stability equal to or greater than products based on 100% synthetic oils. They have excellent thermal degradation properties, and perform especially well in high-temperature applications like racing. [source OIL EXTREME MOTOR OIL: MOTOR OIL: BETTER THAN SYNTHETIC MOTOR OIL basic stock]
for technology and performance of oil extreme click the link OILEXTREME OIL TECHNOLOGY INTRODUCTION: BEST MOTOR OIL: BETTER THAN SYNTHETIC MOTOR OIL
msds click the facebook link MSDS Oil Extreme... | Facebook
hope this help...
That is the claim of the innovator. What we want is proof that this "extreme oil" is really performing at or above par of a given standard. In so far as standardization is concerned, an oil analysis is needed to prove or disprove the claim of the innovator. This will tell the populace if this is really a good oil. An analogy to this is like in the field of medicine, if the "bioassay" & "bioequivalence" of a generic drug (eg brand X) comes close or surpasses that of the original drug (brand O), only then we can say that this generic drug is good or better than the original. In medicine, it is called "evidence-based medicine". Cause at the end of the day, if you can't give us studies or proof, then this product is just another mrketing hype. I do hope you get my point, sir...
