Page 288 of 330 FirstFirst ... 188238278284285286287288289290291292298 ... LastLast
Results 5,741 to 5,760 of 6586
    Apr 2010
    #5741
    Quote Originally Posted by attyallanlatras View Post
    My 25,000 PMS for my Toyota Fortuner is due soon. I have been reading several threads and I am quite convince with the explanations made in those threads that there are better oil filters than what casa is offering. I bought a Baldwin Oil Filter for my fortuner and would want Toyota casa install that Baldwin oil filter, instead of their OEM oil filter. My scheduled PMS is actually just a top-up of 1 liter fully synthetic oil (5w30) and change of oil filter. So my question is would Toyota casa allow me if I ask them to install the Baldwin Oil Filter? Would they refuse and worse consider voiding my warranty?
    they will make you sign a waiver na warranty will be voided
    i argued with them na already
    Jan 2009
    #5742
    Don't bet on it. I requested for something similar about bringing my own oil. They said no. So I do my oil change elsewhere and they in turn, lost a service revenue (however minimal).
    Anyway, you can still have the usual PMS done at the casa except for the oil filter change and the oil top-up. The latter two things you can do yourself in under 10 minutes.
    im curios is that top1 evolution 5w30? magkano per liter?
    #5744
    Quote Originally Posted by shelu View Post
    on the benefit of using Fully Synthetic Oil is more on the duration of the use of such oil in the engine such as 10,000 km vs the mineral oil which has a life of not more than 5,000 kms.
    Delo 400 mgx is a mineral oil but it has been tested for 80k kms.
    Sent from my SM-G610Y using Tapatalk
    Just a question, fully synthetic oil for diesel engines (diesel accent, sorento) safe to use up to 10k kms before oil change on stock oil filters?
    Really want to stretch the OCI to 10k kms or yearly.
    Jul 2015
    #5745
    Quote Originally Posted by istan View Post
    Not safe, iba situations here in ph, example the stop and go traffic here...if highway cruiser lang that seldom idles..by all means
    Jan 2011
    #5746
    yes, you can but it is recommended to change your oil filter at 5k and just top it up with same engine oil. me, however, stick with 5k OCI with oem filter.
    Ok lang yan. But if you’re going to replaced every 5k then just stick to the regular oil.
    #5748
    Volkswagen follows a 15k KM or 12-month cycle for their cars, even the diesel models. Yun sinusunod namin for our 2016 Jetta 1.6L TDI.
    VW casa uses Castrol 5w30 oil.
    Jul 2013
    #5749
    They may be better oil filter than what the casa has but that doesnt mean their filter isnt enough to do the job.
    Even if you use a casa oil filter, your engine will be okay for the next 15 years or so as long as you change oil and filter regularly.
    Jun 2018
    #5750
    Use Baldwin oil filters, instead of OEM.
    #5751
    How do i know what kind of baldwin filter do i buy? Kinda not sure how to look.
    My talyer uses Vic tho. Oil is Amsoil European Car Formula 5w-40
    #5752
    You might be able to get away with a longer OCI if you have a large sump, minimal traffic/idling but it's a lot easier to stick to manufacturer recommended intervals.
    Doing it earlier might be better if you're in traffic most of the time. I don't believe the hyper extended OCI's being marketed by lube companies.
    Dec 2009
    #5753
    I wonder why cruising at 2000rpm is less stressful to the car engine than idling at 800rpm..i simply check the color of the oil against the light
    Before i reach 5000km i check the oil dip stick..if its pitch black then i replace the oil without waiting to reach 5000km
    If its not pitch black when i reach 5000km then i extend it further
    Sent from my SM-G532G using Tapatalk
    you can check the baldwin website for reference bro. the info there is pretty comprehensive
    #5755
    Daily, i just travel 25 kms. I don't idle that much.
    Airport to makati route.
    Thanks for the baldwin info and the check against the light.
    Feb 2015
    #5756
    I agree, you're correct that 800rpm is less stressful than 2000rpm.
    But I think that 2 cars, both with 5000kms on it, one is highway-driven and the other is city-driven,
    it is easier to assume that the highway-driven car is subjected to less stress.
    IMO, engine operating time is still the best indicator for OCIs.
    #5757
    I checked baldwin site. Seems like only gas engines are selectable for Sorento (2.4L & 3.3L) and Accent (1.6L gas)
    try emailing them then bro. i bet they'd answer your query.
    it's not really related to the topic at hand but i did that once w/ k&n air filters when i was looking for a k&n cabin filter for my truck and they replied in a jiffy.
    #5759
    Quote Originally Posted by makelovenotwar View Post
    Agree. A city-only driven car will have run a lot longer in terms of running time vs one that spends most of its time on the expressways with the same km interval.
    For frequent short trips fuel dilution from all those cold starts will be a concern as well. Specially with an older engine.
    For gasoline engines, fuel consumed might also be used to establish OCI's since they run at the same air fuel ratio all the time.
    Harder to do that with diesels since they run pretty lean at cruising speed.
    #5760
    Got it. Will do email
Mineral , semi synthetic or fully synthetic?
