Page 25 of 330 FirstFirst ... 152122232425262728293575125 ... LastLast
Results 481 to 500 of 6586
    May 2012
    #481
    Guys for gas engine: ok na din ba ang:
    1 Total quartz? 5w 40
    2 castrol magnatec 10w 40
    3 zic 10w40 ( kung meron)
    Jun 2007
    #482
    ^ bukod sa viscosity rating, check also the API rating -- should be SN
    Quote Originally Posted by hachooro View Post
    Yung Zic Up maganda.
    Jun 2007
    #484
    yung difference ng semi at fully synthetic eh frequency ng palit? mas matagal ang change oil sa fully synthetic kaya mas mahal din?
    Jan 2012
    #485
    Quote Originally Posted by dfopiso View Post
    Ang gulo hindi ko rin magets. In my case maliban sa budget id go for mineral/semi since hindi naman long trips tapos matagal at abutin ng buwan bago ko ma-reach yung every 5k interval. Pero every 5k ako nagpapalit kaya okay na siguro in my case yung mobil delvac mx at delo 400. Pero kung may budget id go for fully synthetic siguro pag 20k na dame na siguro ako ipon nun. Hahaha!
    May 2005
    #486
    Among the three you presented, use ZIC A 10W-40.
    Castrol daw sludge (latak) maker.
    Not necessarily. SM or SL are better in terms of engine protection due to their higher zinc and potassium contents.
    Jun 2007
    #487
    btw, kung under warranty auto, kailangan sundin owner's manual at policy ng manufacturer
    Sep 2011
    #488
    Mas ok yung Delo 400. API CI-4+ yung rating nun eh. RP is a very good oil din, sure ka na synthetic talaga siya. Pricey lang talaga like all true synthetics.
    Kaya for me, bang for the buck yung Top 1 SDO at Delo 400 eh. Semi-syn na kasi pero yung performance parang synthetic.
    For diesel engine tinutukoy mo?
    Sa gas engine delo ultra di ba ang advice?
    Quote Originally Posted by tomboy View Post
    Depends sa car. If modern car with sophisticated catalytic converter and requires SM or SN rating, 'di puwede kasi rated SL lang. But if your car is okay with API SL, then okay na okay yan. Better check your owners manual.
    Pero kahit Delo Gold Ultra nga yakang-yaka na 10,000kms COI for gas engines. So no need for the relatively more expensive Delo 400 unless laging rezzing-rezzing or under heavy duty use yung gasoline car.
    Jun 2007
    #490
    oops diesel engine pala topic ... my bad
    Jun 2007
    #491
    engine oil pala is one of those that "newer is not necessarily better"
    Yup, it depends upon the car and its requirements.
    Sep 2011
    #493
    Sa Honda EK ko yung delo ultra. Dapat pala nag d400 na lang ako kasi hindi naman sophisticated catalytic nun.
    Buti na lang yung Honda FD, sl din.
    Hindi ko pwede gamtin delo 400 sa fd dahil mataas zinc?
    how about iyong zinc/phosphorous? ano ba ang acceptable content dapat?
    Zinc dapat mga 1200ppm lang sana. Phosphorus okay lang kahit mataas pero usually nasa 800-1100 lng naman yan kahit sa diesel oil pa so not much concern for gas engines.
    ^ hmmm...ang nakalagay kasi dun sa spec sheet .083 ang zinc tapos .076 ang phosphorous.
    May 2005
    #497
    Detergents in the 400 are good protection for the engine but bad for the catalytic converter (due to the high level of zinc and phosphorus). Zinc and phosphorus provide good protection to the engine but its bad for the environment. If you want to keep things in order, don't use it.
    Aug 2012
    #498
    I can't believe how incredibly knowledgeable people in this forum are! this is the reason I joined, to know more about how to maintain my car.
    Tanong ko lang po, I have a 2007 Innova G 2.2L Gas MT, when doing oil changes ang ginagawa ko lang lagi ay bumili ng oil filter sa toyota balintawak at bumili ng mineral oil nila.
    I do not use my ride too often, cguro mga 2-3 days in a week lang na short city drives, and siguro minsan a long drive to Tarlac once every 4-6 months.
    As I read earlier in the thread, I think that was from sir Shadow, sa ganitong profile ng driving, better mag mineral na lang kasi hindi naman ganun kataas mileage/ time ko. Or would it still be better to use fully synth tapos mas madalang ko na lang po palitan?
    What mineral oil and synthetic oil with the best value for cost would you recommend? What oil filter would you recommend? Im thinking kasi na Toyota might be good with cars, but other companies are better with lubricants. or should I just stick to Toyota parts and oil? Thank you in advance guys
    And sha nga pala additional query po: paano malalaman ng noob like me kung may sludge build-up? I always use flushing every oil change. would that help or make things worse?
    Jan 2008
    #499
    Quote Originally Posted by sbayhon View Post
    First off, the/your Innova is only 2.0, i owned one before.
    Choosing between oil types depend on your preferences and budget.
    If you've back read already, there are numerous list of oils here from mineral, semi-synth to fully synth. You did a fine a job by using oem filter instead of VICs (there are better filters out there), IIRC though, the casa uses 20w-50 mineral oil, 30 and 40 weight oil is preferred (check your manual) for better efficiency and response.
    About the sludge, im not so sure, maybe if you take a peek in the oil filler cap? Removing the engine valve cover will give you a better view.
    I dont do flashing, just the regular draining.
    For the filters, lots of members here will vouch for the Baldwins, Fleetguard, Wix, Purolators or if you cant find any of them, there's Bosch.
    For the oils, back read ka konti and you'll see the vast options you have.
    Jun 2012
    #500
    Ano po kaya ok na oil para sa gasoline mitsu 4b11 2.0? kakatapos lang ng 1k pms ko so nilagay nila is mitsu turbo xp gusto ko sana palitan pag 5k na. Driving it everyday to work via slex to makati pag weekends naman pacavite. Binabasa ko manual nung car daming oil na pwede (based on viscosity) hindi ako makapili kasi wala pa ako alam masyado about oil. Thanks guys.
Mineral , semi synthetic or fully synthetic?
