Page 126 of 330 FirstFirst ... 2676116122123124125126127128129130136176226 ... LastLast
Results 2,501 to 2,520 of 6586
    Jan 2014
    #2501
    Quote Originally Posted by chookchakchenes View Post
    Ang problema naman sa baldwin may mga peke binebenta si volmax lalo na yung bf-954 na walang country of origin kaya napikon ako hindi na ako bumili doon. Malayo na nga ang hirap pa pumarada at peke pa ibibigay sayo.
    Gusto ko mag try Mag Baldwin kaso Tamad yung sa volmax. Yung trackzone vs volmax kanino ang mura at orig? Tia
    Posted via Tsikot Mobile App
    Sep 2013
    #2502
    Halos magkaprice lang sila and may item na mura yung volmax meron din mas mura sa trakzone. Pero mahirap pumunta ngayon jan kasi ginagawa abad santos. Nung napadaan ako may mga nagtotow pag nadouble park ka.
    Doon sa sulit seller na lang ako bumibili kasi madali at libre parking at halos same lang price.
    Sir, nasa 150 yata yung bosch na for vios. Bakit ayaw niyo mag baldwin nalang?
    Sent from my Nexus 7 using Tapatalk 2
    Wala na time mag order, lagpas na Odo ko eh. Kailangan na pa change oil.
    May 2010
    #2504
    I'd take bosch vs vic anytime of the day..
    Jun 2014
    #2505
    crosswind car ko. need ko about 25 liters para sa lima kong xwind kaya yun vic at delo 400 combo ko. yung delo 400 pag bulk mas mura sa supplier mismo sa banawe minimum of 12 liters na tig 1 liter or 5liters na 4x. mga 220 lang per liter lumalabas madami kase ako kailangan so sinuyod ko talaga san mura.
    Sep 2013
    #2506
    For 220 pesos per liter mahal ang delo 400 for a mineral oil. Meron iba brand na ganyan ang price na semi-synthetic at api rating ci-4.
    Kung gusto mo imaintain delo 400 meron ka pa makukuhanan mas mura kaso kailangan drum na kunin mo.
    Jul 2011
    #2507
    is delo 400 multigrade a mineral oil only? i thought it is semi synthetic, as it was labeled isosyn, and advertise to rival synthetic performance. satisfied with delo 400 for its balanced protection and performance.
    Sep 2013
    #2508
    Marami klase delo 400.
    Delo 400 LE Synthetic SAE 5W-30
    Delo 400 LE Synthetic SAE 5W-30 formulated with ISOSYN® Technology is our best fuel economy performance motor oil. A top-tier synthetic heavy duty motor oil formulated for reliable performance AND has shown in SAE J1321 Fuel Consumption Tests up to 4.5% improved fuel economy improvement with short haul trucks (Class 6) and 2% with long haul trucks (Class 8) when compared to SAE 15W-40. Promotes consistent cold engine starting. With ISOSYN technology, there’s no compromise on durability.
    Delo 400 LE Synthetic SAE 5W-40
    Delo 400 LE Synthetic SAE 5W-40 has been specifically designed to meet the demands of newer, low emission engines equipped with advanced emission control technologies, while at the same time providing the highest level of performance in pre-2007 engines. This product utilizes viscosity index improvers to promote stable viscosities and soot dispersion between oil drains, contributing to maximum vehicle utilization and minimal downtime. With its low viscosity, Delo 400 LE Synthetic Engine Oil promotes consistent cold engine starting.
    Delo 400 XLE Synblend SAE 10W-30
    Delo 400 XLE Synblend SAE 10W-30 is our latest generation premium quality motor oil formulated with ISOSYN® Technology, Chevron’s exclusive premium base oil and additive technology. Formulated for high-performance across a range of engines and fuel types. Has shown in SAE J1321 Fuel Economy tests up to 3.6% fuel economy improvement for short-haul (Class 6) trucks and up to 1% fuel economy improvement for long-haul (Class 8) trucks compared to SAE 15W-40 oil. Minimizes ash deposits for longer DPF service intervals.
    Delo 400 NG SAE 15W-40 - for mobile Natural Gas
    Delo 400 NG with ISOSYN Technology is a premium CNG/LNG oil formulated to deliver outstanding protection and long drain performance in a wide variety of compressed natural gas CNG, liquefied natural gas LNG and liquefied petroleum gas LPG engine applications. It has demonstrated excellent field performance in a variety of operations and has the capability to help customers minimize operating costs in CNG/LNG engines of municipal bus service, line haul and delivery truck service, waste truck operations and off road equipment. Approved against Cummins CES 20074 for CNG/LNG performance. Approved for use in Cummins 8.3G, ISL G and ISX 12G engines.
    Notable Delo Motor Oils:
    Delo 400 LE SAE 15W-40
    Delo 400 LE SAE 15W-40 is formulated to meet the requirements of post-2007 low emission engines equiped with advanced emission control technologies. Provides outstanding performance with Ultra Low Sulfur Diesel and also with normal and low sulfur diesel fuels, Delo 400 LE is backward compatible and may be used in older, conventional engines and gasoline engines.
    Delo 400 Synthetic SAE 0W-30
    Chevron Delo 400 Synthetic heavy duty motor oil is a multipurpose, 100% synthetic lubricant formulated for use in diesel and gasoline engines operating in subzero temperatures. Its excellent low temperature pumpability leads to less wear at start-up and maintains excellent oil circulation once the engine has started, helping to maximize engine life.
    Delo 400 Multigrade SAE 15W-40
    Delo 400 Multigrade SAE 15W-40 is a premium quality engine oil designed for pre-2007 engines and higher sulfur fuels (> 500 ppm sulfur). With exceptional soot dispersancy and wear control, Delo 400 Multigrade SAE 15W-40 protects cylinders, pistons, rings, and injectors against wear and corrosion, providing optimum service life and minimal maintenance.
    Yung naka BOLD eh yan yung delo 400 sa pinas.
    Kahit yung basic delo gold multigrade at delo gold ultra eh may nakalagay na isosyn pero mineral.
    Jun 2014
    #2509
    drum ako kung kumuha mga 206 lumalabas per liter
    may nakasubok na dito ng top 1 5w-50 for gas engines? very reasonable din kasi ang presyo niya
    gumagamit nga pala ako ng top 1 sdo para sa monty namin at ok naman pero next oil change baka subukan ko naman iyong zic up (tama ba?). dumadami na din recommendation niya lately. pati si bos chokchakchenes na-coconvince na ko
    May 2004
    #2511
    Quote Originally Posted by ronald_ramos View Post
    parang mahal pa rin sir. i am sure less than Ph200/L yan kung drum na.
    Sep 2013
    #2512
    Masyado malapot yung 5w50 sa gas engine. Nasubukan ko na 20w50 (castrol) sa honda engine sluggish ang takbo. Baka hiyang yan sa toyota engine.
    Yung zic dito ko rin lang natutunan yan kay dvldoc and gulat din ako sa performance. Tatlo montero sport ko natry pareha tahimik yung makina. :justhappy:
    Jul 2011
    #2513
    ok yan sir lalo na kung palaging wot driving style,
    after mga 2k sa odo it will gradually become thinner. naobserbahan ko lang sa mga high viscosity multigrade oil.
    Jan 2014
    #2514
    Yung sa sulit sir puede malaman name pang 4m41 at d40 engine meron kaya yun ?thanks
    Sep 2013
    #2515
    Quote Originally Posted by Leo_Arz View Post
    Check mo ito kung meron jan.
    Advertisements of Jason N - Philippines
    Jason N (HondaFDs) - Philippines
    Quote Originally Posted by MrQ5 View Post
    alin ang tinutukoy niyo bos? iyong top1 5w-50 o iyong zic up?
    Jul 2011
    #2517
    yung viscosity wt. nya,
    ^ ah ok bos.
    pero kakatingin ko lang din sa manual ng kotse and hindi pala siya recommended sa fd. so i guess back to 5w-30 or 5w-40 ako. kung sabagay ok naman iyong mag 1 na ginagamit ko paired w/ a baldwin. no problems naman
    May 2013
    #2519
    Hi guys!
    Since you're on topic for Delo 400, I'm contemplating between Delo 400 and Mobil Delvac MX, both 15w-40, almost identical specs but Mobil has superior viscosity index of 140 compared to Delo's 125. Price is mas mahal ang Delo and harder to find. I'm still far away from doing 5k oci, pero parang gusto ko na mag stock ng oil, if Delo ang mapipili ko, it being "rare".
    Your thoughts?
    I'm currently using top 1 hd 10w-30. Btw this is for Dmax.
    I'm open to using other brands, but for now those 2 are my choices.
    Thank you.
    Apr 2012
    #2520
    Quote Originally Posted by bugoys View Post
    Hi guys!
    Your thoughts?
    Thank you.
    Why not stick sa Top 1?
    Maganda Delvac as may experience. Pero mas maganda sa engine ko yung Zic RV
Mineral , semi synthetic or fully synthetic?
