Page 29 of 42 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 840
    #561
    hindi ko alam kung na-post na ba ito, pero may gas station na din pala sila. sa Bocaue. post ko picture mamaya.
    GTOil enhanced din kaya mga gasolina nila?
    Oct 2011
    #562
    sa may bocaue exit lang ba ito?
    Jan 2003
    #563
    Magkaiba ata yung GT Oil na gas station at GTOil na fuel additive.
    #564
    oo. malapit lang sa exit ito.
    iba ang GT Oil gas station sa GTOil
    #566
    baka magulat kayo....si enrichkho makita nyo roon sa GT Oil.
    labag sa prinsipyo niya mag gas station business
    galit sa oil companies yan eh
    #568
    Quote Originally Posted by Bin Diesel View Post
    Baka di lang yun fuel nila na GToil enhanced dyan.
    #569
    Mga alien ang gasoline boys sa GToil gas station...and freebies for a try yung oil aditives nila...
    #570
    pagnag karga ka sa GTOil gas station. One time full tank lang paps. NO need for succeeding fill-ups. Perfect combination sa NO change oil BS nila hehe.
    May 2009
    #571
    meron din GT Oil station sa may lapaz, tarlac. nagulat nga ako eh baka additive lang yung ilalabas ng pump nila. freebie yung diesel. nyehehehe
    #572
    this is the picture. i dont know if they are the same company..
    di kanila yan
    kita mo may Castrol
    diba no change oil forever? baket sila nagbebenta ng motor oil?
    at iba ang logo
    Jan 2003
    #574
    yes. magkaiba nga.
    nasisira pa pangalan nung gas station dahil sa hoax additive.
    #575
    Seen this in the GTO website, and just want to share for your comments mga masters....
    WHEN NOT TO USE GTO?
    Bros, Gentlemen and Ladies:
    PLEASE BE INFORMED:
    Based on a few and probably very rare incidents.
    I am taking the liberty to make this new guideline for all:
    There are a few notes each distributor/stockist or OTG Tech Guy should take and enact before treating any vehicle or engine with GTO.
    1. Be sure there is no Teflon content on the previous oil; If sooner or later you found out there is after the treatment, simply drain the whole oil and flush it, replace with normal multi-grade oil and repeat GTO treatment as per suggested dosage from the guide.
    2. Be sure to check the condition of the engine oil first and foremost!
    a. VISUAL CHECK: If there is a trace of grayish ash matter with the oil - DONOT treat with GTO. (You must DRAIN the old oil and flush it IMMEDIATELY!, replace filter and oil)
    b. FEEL CHECK: With your fingers, feel the oil for smoothness and or roughness, IF THERE IS A SANDY FEEL, Do not treat with GTO! (Drain and Flush immediately! replace filter and oil)
    c. SMELL CHECK: With your nose, Check for smells of fuel (Gasoline or Diesel), if there is a smell of fuel, it means, there is dillution. (Draining and Flushing of oil is OPTIONAL, if oil is still clear with metallic particulates, then it's ok to retain this oil);
    d. STAIN CHECK: Drop a few old engine oil on your fingers, rub it a few times, then wipe it off one time with a clean cotton clothe or tissue paper, if there is a dark stain left on your finger tips, Do not Treat with GTO! (The dark stain is from metallic particles suspended in the old oil) Treating this with GTO may cause accelerated damage to the engine. (Drain and Flush immediately, Replace with Fresh ordinary oil then treat with GTO according to suggested dosage from the guide.)
    3. Any condition not listed above, a trained/ qualified OTG Guy/ Technician should be able to discern himself and is expected to give the appropriate recomendation; There is a need to have a qualified and well informed OTG Guy/ Technician in every locality in order to service and cater to the public.
    PLEASE BE GUIDED ACCORDINGLY.
    see this link: The Green Technology Oil: WHEN NOT TO USE GTO
    So kayo dyan, PLEASE BE GUIDED ACCORDINGLY.......
    #576
    ^ As if someone will actually put GTOil in their vehicles. Well... except for the alien, enrickho, of course.
    Quote Originally Posted by attyallanlatras View Post
    PLEASE BE INFORMED:
    pang laban sa demanda pag nakasira ng makina?
    #578
    TumpaK!!! kulang na lang taste test panigurado wala demanda.
    Dec 2007
    #579
    PLEASE BE INFORMED:
    You forgot if you have a basic understanding of engine oil and the internal combustion engine and how it works and what makes up oil. And the fact a filter made of paper cannot last forever nor that adding a oil additive will remove the byproducts of internal combustion magically from the engine if you never change the oil. Or how oil reduces emissions by 30% to 50% or gives the same in power.
    Biggest stupidest scam just about anyone ever has seen, Big in Cebu but nobody else is falling for this crap product. It's the laughing stock of the internet.
    I love there methods for testing oil, would not a engine oil analysis tell you everything you needed to know?
    Also not these check invalidate the claims of the oil that it dissolves all particles in the oil, How many times did I ask how does it disolve wear metals and got no answer, now they say if you add it it would increase wear, would that not be the opposite if its such a magic lubricant.
    Let fools use foolish products. Please stop trying to push this already totally discredited product.
    Dec 2007
    #580
    More insane claims from this product, Now they say you can run your car without oil or coolant and it will protect you. I also like how they claim the cost of other treatments are so expensive.
    From the originators of this scam product the our little friend in India.
    GTOIL TREATS FLOOD SUBMERGED ENGINES TOO
    Enforce GTO engine oil treatment in your engine oil and your flood-submerged engine will come back to life. GTOIL ensures that there will be no harm to your engine making it safe and drivable again. When you use GTOIL , it also serves as a protection against water reacting on metal parts and forming rust on crankshaft , connecting rods,bearing etc. Even if your engine is flooded, it will be protected.
    Engines exposed to flood have water retention even after oil change and engine flushing. This makes your car drivable but UNSAFE. The residual water in the engine can not be eliminated by any mechanic unless they use GTOil. This ensures that water wont do any damage in the engine.
    Performance Coating Against Overheating
    Normally, Ceramic Coatings cost INR 25,000/ minimum & Molybdenum Coatings cost INR 50,000/ minimum! GTOil costs only a fraction to that cost and out-performs all types of racing performance coatings for it has the highest threshold for friction and heat, there by guaranteeing no engine stoppage!!!
    PROTECTION TO METAL PART FROM HEAT
    Metal surfaces, as do other forms of matter, expand after absorbing heat and for the engine, this spells cracking of the cylinder block leading to engine breakdown and engine stoppage. GTOil forms a protective shield AROUND, WITHIN & IN BETWEEN the atomic spaces of metal that even the highest temperature could not penetrate it, thereby protecting all the metal parts of the engine from destruction via heat! Yes this makes our product the only product in the world with nanotechnology!
    DRIVING WITHOUT FEAR
    GTOil offers maintenance-free driving for you wont have to check the level of engine oil or radiator water! GTOil is the only product in the world that could make a vehicle run without oil and water! So even if your driving to the rural area, you won’t have to worry about an exploding radiator hose or a leaking oil gasket, because even if you run out of water or oil, we guarantee no engine stoppage! Therefore, you could still go home! Nothing could be more comfortable than this! If safety and comfort could be bought, then buy GTOil!
    Also not they added about changing the oil filter but still leave up the claim you never have to change it on their page.
    1) GTO Revitalizes your existing engine oil.
    2) No need to change oil at regular intervals(provided the engine oil is in good condition).
    3) Need to change oil filters every 10,000 kms.
    4) Reduced maintenance by more than 50% or more!
    5) Cooler Engine temperature
    6) Extends Spark Plug and Battery life! (no carbon formation/quick starting)
    7) Reduced Emission upto 80% or more
    8) Increase engine vacuum
    9) Increase engine power by 20% or more!!!
    10) Increase fuel mileage by 20% or more!!!
    11) Prevents galling ( which can lead to gouging and scoring)
    12) Virtually eliminating metal to metal contact and greatly extending part life.
    Seriously people get real.
Has anyone heard of GTOil / NOW12? Is this a scam?
