Results 1 to 7 of 7
October 25th, 2014 10:54 AM #1
Good day mga boss ask ko lang kung anong problem sa corolla ko.this morning did my usual rountine na I start at check lahat ng nasa loob ng engine bay napansin ko lang na may basa yung area ng fuel injector halatang may leak.barado ba fuel injector o may palitin lang na o ring.
OT : OBD I b o OBD II ang corolla 96.may nagbebenta kasi ng obd scanner sa kin kaso di ko sure kung pwede sya sa oto ko.
October 25th, 2014 03:37 PM #2
Amoy gas ba? If not clean it and observe again.
Kung 16 pin obd2 kung 2 pin obd1.
- Apr 2013
- 236
October 26th, 2014 02:16 AM #3No need na ng obd scanner ng corolla 96. 2 pins lang yan. Sa diagnostic port. Short TE1 and E1. Blink lang ng check engine light sa dashboard ang babasahin. Well google mo na lang how to diagnose sa google. Regarding sa injector. Baka o-ring lang yan.
Posted via Tsikot Mobile App
October 26th, 2014 07:42 AM #4
Salamat sa reply mga bossing.amoy gas nga sya i checked it again earlier today.tignan ko kung makaya ko diy na kalasin at palitan kung ano man yung problem pag hindi takbo kay suking mekaniko
- Jun 2010
- 321
October 26th, 2014 09:12 AM #5wag mo muna gamitin yung rola mo delikado yan baka masunog car mo, malamang oring ang busted need mo nang palitan kung mechanicaly inclined kang madali lang palitan google or search ka sa you tube, need mo remove fuel rail para mahugot ang mga injectors ingat sa pag remove kasi pressurize yun, if ipapagawa mo isabay mo na ring palinis injectors.
- Aug 2014
- 391
October 30th, 2014 09:57 PM #6Baka Oring nga yan. Naka pag try ako mag linis ng EFI, 9 Volts baterry, tapos yung presurized carb cleaner. Kung EFI nga yan, 9 volts, kabit sa contact pins, tapos click click lang .. kabit mo sa carb cleaner, para macguro mo na meron pang fuel na lalabas sa injector mo.
October 30th, 2014 10:06 PM #7
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
