Results 1 to 10 of 36
- 61
June 13th, 2004 05:41 AM #1Guys ok lang ba magEngine Flush before Change Oil ? Ive done this before but some told me, its not good, it doesnt help. Just curious, malapit na kc ko mag change oil eh. mine is civic98. Thanks.
June 13th, 2004 10:20 AM #2
NO, it's one of the best ways to ruin your engine.
basta regular ang change oil schedule and the oil does not get too dirty di na need yan mag-engine flush. engine flush is mostly kerosene with detergents added to it. can you just imagine what that will do to your engine, running on oil diluted with kerosene?
for me i would rather drop the oil pan, clean it out, then put it back again with a new oil pan gasket. sigurado ka pa na nalinis talaga lahat ng sludge at carbon sa oil pan mo.
June 14th, 2004 01:42 PM #5
yup, dagdag gastos lang yan.
i remember, meron isang car care service station dati na binebentahan ako ng magnetic na drain plug, para daw yung mga maliliit na bakal from the engine dun lang nakadikit. i don't know kung effective talaga ito. pero hindi ko pa rin binili.Signature
June 14th, 2004 08:37 PM #6
If u want u can use as a flush yung mura na oil lang. Yung pinaka mura.
After you drain it just put the cheapest oil then paandarin mo lang nang 2 to 3 mins. then drain it again u will see na medyo dumumi yung kalalagay mo lang na cheapest oil.
Then put na yung ano mang gusto mong oil, kung synthetic or semi synthetic.
my 2 cent lang...
- 61
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 15th, 2004 09:19 AM #8nuff said... if you follow your service intervals then there is no need to flush the oil
June 15th, 2004 09:50 AM #9Originally posted by CLAVEL3699
my 2 cent lang...
I do this with our rides every 30,000km or so.
Tsikot Member Rank 3
- Apr 2004
- 663
June 15th, 2004 10:08 AM #10Pero you'll need to flush when you switch from mineral to synthetic, right? That's what I gathered from other threads.
Yebo, kerosene ba ang pang-flush? 'Diba oil din (specifically made for flushing)?Last edited by RafRaf; June 15th, 2004 at 10:13 AM.
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
