Results 1 to 10 of 25
April 13th, 2014 09:07 AM #1
Hi mga sirs!
I have decided to go full restore mode on my pre-loved EE90 instead of buying a new one. She had her 2E overhauled in 2006 and i wanted to give her more longevity and so, I want to have a new engine for her.
Im currently torn between 4efte or a 4afe, Ill make that decision once funds are avail in a few months. I just need a second opinion on what I was quoted by a top of the line and well respected tuner in banawe.
The owner said I would need anywhere between 150k- 250k because of:
- Engine and Tranny Price
- Gas Tank Change - He said Gas tank of a carburetor engine is different from EFI. Is this true?
- Fuel Line -- since we have a different gas tank, we have to redo the whole fuel line as well, including exhaust and wastegate if im going to go for turbo. I agree for the wastegate but is the fuel line change necessary? I dont have a clue about the fuel pump of an EFI and how it works
- Clutch and Brake Assembly will change to accomodate power change
- Suspension check and change as necessary as the new power unit and tranny will be heavier than the stock 2E
- Radiator and cooling line change as needed - I have huge ass radiator and aux fan to boot so I know this wont be a problem
Your thoughts?
- Aug 2013
- 475
April 13th, 2014 03:07 PM #2150K is just right for 4efte. but why 4efte? you're into need for speed? just kidding
1. Engine and Tranny
4efte = 60K to 70K with tranny and install but if you're on a tight budget, you can reuse your old tranny and the good part is, its a direct bolt on to your chasis.
4afe = more or less 50K with tranny and install, it needs a different engine support and its not bolt on.
2. for EE90 or AE92, it needs to be changed to an EFI gas tank, good mechanics can convert it to EFI, going rate for a surplus EFI tank would be 6500 to 8500 and its rare.
3. fuel lines? no need to change.
4. clutch and brake assembly, no need to change, but if you have the budget, you can change it. if you're eyeing for the 4efte, i would suggest to get levin big disk up front with good brake pads. more or less 3500 for the levin brakes
5. suspension? no need to change. good brakes are better.
6. radiator? no need to change.
the life of an EFI engine is in its wiring and sensors. source a good mechanic to do the engine change.
for me, if you are not into speed and the car's main purpose is to go from A to B, you can add to your options the 5efe, its a direct bolt on same with the 4efte but its a 1.5L engine. good low end torque. find the 3rd gen, its the most fuel efficient one.
April 13th, 2014 04:41 PM #3
Why the 4efte? For the same reason you said. Its a bolt on. The deciding factor is the turbo. Gusto ko dn maramdaman pakiramdam ng may extra umpf! Hahaha
Thanks pala sa input sir. Ill also check the 5efe. I know a placd or three sa paranaque that i think can quote me something lower haha.
While we are at it, the well respected tuner from banawe also told me the whole transplant will take 3 months. Tama ba un?
Samsung N9005 powered by Smart posted using tsikot mobile app
- Aug 2013
- 475
April 13th, 2014 09:04 PM #4naku paps. sorry to say pero 3 months? sobrang tagal nun.
an experienced mechanic can do the transplant in 1 day. even faster if the wiring harness of the engine you bought have no cuts and/or missing or defective sensors.
if you can't source out an EFI gas tank for your small body corolla, you can still use your old tank but be sure not to drive hard when your fuel is the below 1/4 mark, you will experience fuel starvation, lalo na kung high cornering speed, your engine will shut off or lose power due to less fuel supplied in your engine. hindi kasi baffled ang carb gas tank ng small body.
- Jul 2013
- 2,450
April 13th, 2014 09:27 PM #5Koya She of SB salon is quite popular in toyota forums before. I have no experience with him but reviews years ago were really positive. He is into running now so i am not sure if he still swap engines on a regular basis. Look him up in fb.
Sent from my GT-N5100 using Tapatalk 2
April 14th, 2014 04:39 AM #6
Uu ive heard of sb salon before. If were talking about the same thing, ito yung shop sa cavite right?
Thanks sa info sir! Nasabi dn nga nung owner nung famous and well respected tuner shop from banawe (sorry dont want to name names) that there is a cheap ass way of doing it, which is this way, not changing fuel tanks or replace the fuel tank which is my option actually.
So matagal pala 3 months hahah. Kaso kasama na daw dun ang paghanap ng engine, tranny then install then making sure tip top running condition... pero thanks pa dn sa info. At least i have a baseline kung what goes on for a change
- Aug 2013
- 475
April 14th, 2014 09:44 AM #7tama sabi ni Lew_Alcindor.
Si kuya Sherwin or She for short of SB Salon. Wala na akong contact number niya, taga Gen. Trias Cavite siya.
Isang malupit na mekaniko. He can help you to source out your desired engine of choice.
April 14th, 2014 06:49 PM #8
- Aug 2013
- 475
April 15th, 2014 11:08 AM #9paps, mukhang active pa siya sa pag change engine. message mo siya sa facebook. "koya she Sbsalon" search mo lang.
goodluck sa project.
- Apr 2011
- 13
April 15th, 2014 02:26 PM #10Sherwin (SB Salon) - 09178818580. He made two engine swaps for me. Wiring is OEM. You will never go wrong with him. HTH.
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
