Results 61 to 70 of 1853
- Jan 2007
- 409
May 12th, 2011 08:02 PM #62
May 12th, 2011 08:15 PM #63
for the 1st 2 fill ups muna... then siguro, 25-30 ml nalang papalagay ko every fill up...
- Apr 2011
- 78
May 12th, 2011 11:40 PM #64okz i understand...... hindi po repacked...original package po na bottled.... d ko makita yung date of manufactured...hindi naman ata nag re-repackaged yung SM.... doon mismo sa ACE hardware ko nabili.... bumili ulit ako kanina sa ganun pa rin ang price 95 pesos per liter kaya....
i tried it with the trooper....so far maganda pa naman ang takbo....... less y8ung vibration at ang usok pag bagong andar hindi masakit sa ilong.... mabilis nawawala yung usok....
May 13th, 2011 08:43 PM #65
You can also reduce the amount you use a little bit at a time to see what still gives you the same effect. Remember every car is different. The 200:1 Ratio is just a starting point. Whatever you can do to lower cost and have a better running engine is what you should go for.
May 14th, 2011 08:31 AM #66
*dvldoc
is the engine of your elgrand the same as local frontier 4wd(qd32)--pre-navarra model or the same with those found on the 1st batch of new patrols(2004?) and urvan estate?
basta di crdi pwede to diba?
May 14th, 2011 11:00 AM #67
Yes, It's just has a turbo and electronic controlled injection. They do have some different items like they don't run the same oil filter, and the compression ratio is different but basically the same. The Elgrand engine is the QD32ETI rated at 150hp, I think they are under rated from the factory because all the ZD30 Turbo motors don't come close on HP.
- Apr 2011
- 78
May 14th, 2011 02:55 PM #69sir,mahal pa yung pasahe kaysa sa price pag dto ka pa bumili.....nasa iloilo kay ako...hheheehehheehehe.....anu sa tingin mo? check ko ulit pag mayroon pa....
bibili nga ulit ako para sa jeep nmin na pampasada... gumaganda daw yung takbo at saka ang hakat ng engine sabi ng driver namin...
thanks pala sa advice regards with the brakes at trany....ako lang kasi ang nagplit ng brake pads at atf....
May 14th, 2011 04:58 PM #70
Papunta kasi ako dyan sa June, sayang nabago sched ko kaya hindi pa this week. Hoarding ako sana eh. hehehe. Grabe price-off yan kasi, 62% markdown!
Wow, DIY master ka rin pala. Ako hindi ko kaya yung sa ATF, R16 na tires ko pero sayad pa dibdib ko eh (may rollers naman ). Kaya sa shop na lang at may lift pa. hehe
OT; magkakano bili mo bendix? Metal king ba nabili mo?Fasten your seatbelt! Or else... Driven To Thrill!
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
