Page 65 of 93 FirstFirst ... 155561626364656667686975 ... LastLast
Results 1,281 to 1,300 of 1853
    Oct 2007
    #1281
    Quote Originally Posted by K.I.L.L. View Post
    Oh well that's good. I always thought that the new CRDIs didn't like 2T.
    maybe the newer CRDi's sir...
    #1282
    I've been using 2t (castrol 2t fc) on our 2013 fort 4x4 and 2007 innova. Less engine noise and less black smoke.
    Jul 2013
    #1283
    Quote Originally Posted by al shaheen View Post
    Pwede din ba ito sa adventure?
    ok lng po adventure po gamit ko
    #1284
    is petron 2t premium ok? it's rated JASO FB+, API Service TC.
    #1285
    Yes. Okay ang Petron Powerburn 2t.
    Aug 2011
    #1286
    ilan ml ng 2t ang pwede pong ilagay pag full tank ang crosswind? 55liters ang capacity po.
    Sent from my ALCATEL ONE TOUCH 5020E using Tapatalk
    #1287
    Quote Originally Posted by nivraarvin View Post
    but petron powerburn is different from petron 2t premium
    #1288
    Okay. My bad.
    Never seen 2t premium. I'll give it a try pag may stocks dito.
    Jul 2006
    #1289
    Okay. My bad.
    2t premium is i think is a synthetic blend
    #1290
    Took a look at the Petron website.
    2t Enviro - "Semi synthetic" Jaso FC
    2t Powerburn - Jaso FB
    2t Premium - Jaso FB"+"? Requiring only half dosage compared to Enviro and Powerburn.
    I'm having trouble finding a Petron station with 2t premium and 2t Enviro.
    #1291
    Quote Originally Posted by sirmykel View Post
    same thoughts that's why i'm a bit hesitant..
    May 2013
    #1292
    Question... Anyone notice a diff in performance with 2t between regular diesel like shell's fuel save vs. what i assume is low or lower sulfur diesel like the v-power nitro diesel? Im curious if anyone's had the fuel save run smoother that vpower with 2t.
    Dec 2007
    #1293
    Quote Originally Posted by Rethinker View Post
    I do. Been using VPN+D when I tried the fuel save last Nov. The car felt sluggish. Now I'm back to Nitro+ again. Don't know if there is difference in sulfur but it should not be the reason. Probably the Cetane value difference.
    Sep 2010
    #1294
    Quote Originally Posted by mumuy View Post
    Hi everyone... Will it be safe to put 2T (Shell FB) to my 2013 Innova D4D vehicle which is only at 7k km on the odo? TIA
    Mine is approaching 10K. had PMS at 9500( change oil and optional fuel filter replacement). Added 125 ml/full tank - Unioil+Castrol activ 2t). Am about to consume my 2nd full tank. Indeed, NVH is reduced significantly only after the first tank, noticeable on idle with engine seemed relaxed. Will continue using 2T.
    #1295
    Im sorry Im just using mobile and did not read all reply. Any feed back on 45d6 L300 model 1998? Does it work? Pros and cons. Thanks in advance!
    #1296
    Also what is the equivalent value of 200:1 ratio. Is it 40liters of diesel to 200ml 2t? Sorry not good in math.
    Sent from my GT-I9505 using Tsikot Forums mobile app
    #1297
    Quote Originally Posted by georgejr05 View Post
    2T is good on a 4D56 engine. A lot of tsikoteers here already uses 2T on their Adventure, L300, and Montero Sport. For the ratio, you are correct.
    #1298
    Thank you for the quick reaponds. Will try it later
    #1299
    I've been using it on my 4d56 turbo, quieter engine, less smoke. No cons.
    Sent from my Nexus 7 using Tsikot Forums Mobile App mobile app
    Aug 2013
    #1300
    Quote Originally Posted by fredgimed View Post
    i would like to ask sir if you have tried other brand of fuel? i used this combo of diesel with 2T since my innova was running less than 2000 Kms and upto now with current mileage of 8XXX kms, since the first day I tried it, i only used shell V-power nitro+ diesel with shell 2T.
    i want to change my fuel from shell to Unioil (Euro 4 compliant) for the reason that its better for our engine, did it affect the engine performance from shell to unioil? thanks
Diesel owners that add 2T oil to fuel
