Page 60 of 93 FirstFirst ... 105056575859606162636470 ... LastLast
Results 1,181 to 1,200 of 1853
    #1181
    Overall ok naman cause way less smoke. Fc seems to be the same. Halos walang smoke na.
    Aug 2009
    #1182
    Less pm cost for our injection pump. Gayahin din kita idol cb, hehehe. Will try it in my nxt fill up. Thanks again po.
    Apr 2013
    #1183
    ^Been using that combo for the past 2 years.
    Sir cb,will this be good to use on 2012 adventure with 4d56 engine?
    #1184
    Quote Originally Posted by cardict View Post
    Should not have any problem. Im using CI-4 rated oil also.
    Apr 2013
    #1185
    Thanks ,copy sir cb
    Jul 2013
    #1186
    sir need po advice meron po kaming Mitsubishi adventure gx noong 2012 http://i158.photobucket.com/albums/t...psd1d7c662.jpg (here's the engine) ask ko lang po if ok bang gamitan ng 2t ito or meron na po ba naka pag try na mag lagay ng 2t sa sasakyan na ito..
    TIA;
    May 2012
    #1187
    I'm a believer pati na din si repats Shel V power Diesel Nitro + 2t Shell = Ulala. . . Ganda ng performance engine noise while driveing nabawasan at hindi na ipit ang tunog pinong pino na siya. Inoobserve pa namin yong konting nginig pa at white smoke sa unang engine start
    Update ko pa kayo BTW. 2012 Crosswind pala tsikot namin 20kms na kaka PMS lang
    #1188
    Quote Originally Posted by homework View Post
    TIA;
    Sir homework, hindi mo naman ginawa homework mo naisagot na po yung tanong niyo few pages back.
    Jul 2013
    #1189
    thanks sir nabasa ko na po now lang na tapos cenciya na sir medyo mahina ako sa math pano if 1000 kinarga ko ilang ml ng 2t ilalagay ko ok and ok lng po ba ang sea oil with power of stp SEAOIL Philippines Inc. » SEAOIL introduces racing-edge STP additives to fuels | News
    plus 2t ng sea oil (30) ok lng po ba 2t nila or shell carbonize
    Aug 2008
    #1190
    ^^ the correct ratio, to make it simple is, 5ml of 2t per liter of diesel. You can experiment using seaoil diesel and their 2t then on the next fuel refill, shell 2t. Then observe which is better.. better also if you share it here.
    Jul 2006
    #1191
    san ba makakabili ng FC rated na shell 2T? puro kasi FB lang nakikita ko sa gas stations nila. wala akong comparison ng before and after ng performance/improvement using 2T kasi pagkakuha sa casa naglagay nako simula ng unang topup ko hanggang ngayon.
    Aug 2008
    #1192
    Quote Originally Posted by sirmykel View Post
    Have not seen an fc rated shell 2t. You can try ptt, they have it in their stations. Im using ptt.
    Jul 2013
    #1193
    sir na back read ko na po lahat ano po ba pinag kaiba ng FC and FB ano po ba ang pinag kaiba at ang maganda at pangit sa kanila thanks
    Aug 2008
    #1194
    Sure ka lahat? your question is answered in the first pages, devildoc had a discussion on this..
    #1195
    Quote Originally Posted by rac98 View Post
    nasa page1 na yung sagot. first post pa
    Jul 2013
    #1196
    Not much on this here so I thought I bring it up, Pretty common practice in the states on older diesels, I run it in my Elgrand 3.2 turbo diesel when I first got it the engine use to shake a lot more than I liked so I went ahead and started using 2T oil. First thing I noticed is the engine was so much quieter and smoother after the first full tank, I got a little bump in fuel economy as well and it eliminated the harsh shut off shutter I would get when I would turn off the engine.
    Let's just get the basic question over with,
    Will it hurt my engine, NO if used as described 200:1 mix ratio. example 17L tank = about 3oz 2T.
    Will it clog my fuel filter, NO
    Will it mix with diesel, Yes
    Can you use it with Bio-diesel, Yes
    Can I just add it every other tank, or whenever I want, Yes
    What's the best 2 stroke oil to use, The cheapest is the best no synthetic.
    Do I have to get the mix exactly right, No you can be a few oz or so over without harming anything. (Brother in law dump a 8oz bottle in the Elgrand had no issues) Told him 3oz)
    Should I use this on Common Rail diesels, Yes but nothing made after 2006 (which is the 2007 model)
    Does it give you more horse power, NO
    Does it change the Cetane rating, NO
    Also added it to my friends Kia Prego which you could hear comming down the block due to engine rattle, He was also very impressed with how smooth the engine became after adding it. He's been using it since Last November and plans to keep using it.
    Also did it on the family 1999 Starex, major improvement on that thing as well it use to shake like crazy at idle, I would say about a 80% improvment after 2 months of use. So for 100P to 60P for 8oz bottle it's not a bad investment. Especially for your fuel pumps life.
    Mix ratio is 200:1 by volume of fuel not ment for 2007 Up diesels.
    Here's a study done on it
    http://rivrdog.typepad.com/files/cop...-version-3.pdf
    In two-stroke oil we get 4 different quality ratings, which are based on the JASO (Japanese Automotive Standards Org.) scale:
    JASO-FA very basic single grade SAE30 or SAE40 based 2-stroke oil (premix only)
    JASO-FB Used for most premix industrial 2-stroke engines and scooters
    JASO-FC "Low ash burn" used for separate oil injection and most outboard motors. this oil can be mineral or part synthetic
    JASO-FD This is fully synthetic 2-stroke oil for racing engines. It is not suitable for mixing with diesel
    2T oil listing and ratings. You want to use the Low ash JASO-FC
    http://wcsdistributinginc.com/WCS%20...aso%20list.pdf
    I know several other Elgrand owners running it with a nice noticle difference It would be good to hear from other older diesel owners who also run 2 Stoke oil in there fuel. My Elgrand never ran smoother and I will keep using it every tank of fuel.
    It even beats out Amsoil when it comes to improving lubercation.
    The mixture of JASO-FC compliant 2-stroke oil further reduces soot and carbon deposits. this is the main reason, why the burn free cycles of particle filters are extended when using this practice. A further benefit is the increased reliability of CRD high pressure components, such as VHP pumps and injectors
    Lets here your stories or questions.
    ito mahina kasi ako sa english sir highschool grad. lang po me sir....... ano po ba ang magandang gamitin dito
    Dec 2007
    #1197
    Huwag mo na pahirapan sarili mo, yung FB lang gamitin mo.
    Aug 2008
    #1198
    Hanap ka na fb na mura. Ok na yan.
    Jul 2013
    #1199
    Quote Originally Posted by timo07 View Post
    salamat sir timo07 ano po ba 2t oil na fb sir shell po kasi nagamit ko now..... thanks po ulit
    Dec 2007
    #1200
    Yes, Shell 2T decarbonizer. In small yellow bottles (200ml) at P27. Okay na yun.
Diesel owners that add 2T oil to fuel
