When using Unioil Euro IV diesel, maybe it's not necessary to add 2T anymore since Unioil adds additives already for lubrication. Any comments or Ideas on this line of though?
Mga boss ask ko lang po pwede po ba maglagay ng 2t sa 2011 mitsubishi montero sport 4x2 manual 2.5 diesel?non VGT po at shell Vpower po fuel ko. Gusto ko lang po makasiguro.so far sa mga nabasa ko maganda feedback sa mga iba diesel engine user.salamat po
If you will double click the link dun sa page 1 it will giveyou a PDF file that will answer your questionand enlighten you why you might want to add 2T although for ULSD yun and sa ibang bansa yng study na yan pero kung tinatamad ka basahin eto in a nutshell : "....There have been many documented cases of randomly tested samples of diesel fuel. These tests prove that often times the fuel we purchase is not adequately treated and may therefore contribute to accelerated wear of our fuel delivery system"
A possible interpretation to what butchyboy is saying is that oil companies might not be true to their word. They might be putting less or none at all. Afterall, added cost sa kanila yung additives in addition to the extra processing cost to remove sulfur.
Sent from my GT-N7100 using Tapatalk 4 Beta
Sinubukan ko mag Seaoil Diesel + Seaoil 2T ulit after using Petron Diesel Max + Petron Powerburn (yellow bottle) for quite some time. Felt a noticeable decrease in power, lumatâ manakbo. Might try using
Petron Powerburn with Seaoil Diesel next time, to rule out the 2T factor, but I doubt na mas maging better sa Petron Diesel Max + Petron Powerburn mix.
I will also try Unioil ulit pero sa nabasa ko din dito before from sir dvldoc masyado na mababa lubrication ng Euro4 diesel for older engines like 4m40 (pajero fieldmaster) even mixed with 2T di pa din sapat.
Nasubukan ko na din before ang Shell, nakulangan din ako sa power vs petron diesel max, fuel save ata yun pero sure not the nitro or yung counterpart ng turbo diesel ng petron.
Petron Turbo Diesel + Petron Powerburn 2T gave me the best performance, gigil na gigil talaga power bawat tapak sa accelerator, para kang tinutulak pag hataw sa highway bilis mag 130kph above bibilang ka ng overtake-an sa nlex/slex/sctex/skyway/actex...testing mode lang naman keep safe pa din mas importante, point is when you need extra power this combo will definitely help. I only use turbo diesel + powerburn 2T pag long drive, yung extra power kasi ng diesel max + powerburn 2T is enough for me sa city driving, and may adverse effect din daw sa engine ang exclusive use of PTD.
Petron Turbo Diesel alone without 2T gaspang pa din manakbo same with other diesels without 2T mix lalu kung nasanay ka na sa benefits ng 2T oil. ;)
Sent from my ifive MINI 2 using Tapatalk 2
Euro3 nalang yata seaoil.
Wala naman problem with euro4. Matagal ko na gamit. Around 2 years na hehe
Ako sa napansin ko naman, parang mas ok ang Shell Fuel Save at Shell 2T combo. Mas pino ang hatak at tunog ng makina. Sablay naman sa akin ang Shell 2T at Petron Diesel Max combo. Ang gaspang ng makina at di ok ang hatak. Yun Unioil at Shell 2T combo para sa akin ay maganda rin.
