Page 53 of 93 FirstFirst ... 34349505152535455565763 ... LastLast
Results 1,041 to 1,060 of 1853
    Apr 2011
    #1041
    hello sir dvldoc,
    dont know if i am in the right thread just want to ask your idea regarding oil catch can that is installed under the hood.its benefits and performance.i got a blowby engine as well.thanks
    Jan 2010
    #1042
    just tried using 2T to my advie for 1week, indeed its effective... thank
    Apr 2011
    #1043
    Almost half tank na since naglagay ako ng Shell 2T. Mas pumino yung andar. Sa hatak pansin ko na mas kelangan mong tapakan ng mas madiin compared before. Di ko alam kung dahil iba ren ang kinarga ko instead na usual caltex fill up ko.
    Sent from my GT-N7000 using Tapatalk 2
    Aug 2008
    #1044
    Try checking your fuel filter. Baka madumi na.
    Quote Originally Posted by halimaw View Post
    After using shell with decarbonizer, seaoil, and petron 2Ts
    Nag settle ako sa Petron Powerburn yung dilaw, got best results with it.
    Mas noticeable yung less vibration, kinis manakbo at less nginig on engine off. At kahit malapit na sa 1/4 fuel gauge ko same pa din pino makina, sa iba kasi napansin ko pag pa 1/4 na gauge medyo nabawasan positive results.
    More than a year 2T user, pajero fm.
    Nasubukan ko na din dati, from manila to subic petron turbo diesel without 2T, putek ang gaspang (nasanay na siguro kasi ko sa 2T results)
    Pauwi nagkarga ko sa petron sbma diesel max lang plus 2T, hanep talaga nagagawa ng 2T, noticeable linakas hatak at kinis eh, parang gasolina manakbo at pansin ko mas tipid konsumo.
    Attachment 18906
    Hehe, same experience tayo sir. Ang hirap pala masanay sa 2T ng old school diesel engine.
    I-try ko pala yang powerburn but yung mura kais is yung National 2T, kakabili ko lang, try k din sana.
    Apr 2013
    #1046
    Quote Originally Posted by nvidi.turion View Post
    year model sir ng advie please
    Aug 2010
    #1047
    magkano yung petron 2t powerburn 1 liter?
    #1048
    Quote Originally Posted by trucker111 View Post
    100 / liter bili ko last year sa auto supply sa blumentrit.
    Apr 2011
    #1049
    Quote Originally Posted by rac98 View Post
    Will do. Due for 60k pms na ren ako.
    Aug 2010
    #1050
    jaso fb ba ang petron 2t power burn?
    Aug 2003
    #1051
    Bought powerburn at 126/L earlier sa gas station. Yes jaso FB same as caltex and shell's 2T.
    Feb 2013
    #1052
    Apologies if this has been answered and being such a simple question. Do you put 2T oil before, after filling up or it should be in-between? Or this doesn't matter?
    Thanks!
    #1053
    Quote Originally Posted by gearguru View Post
    Thanks!
    It doesn't matter, 2t concentration within the diesel in the tank will eventually even out. But if you want it to happen sooner, then add 2t first, then fill up.
    I usually fill up first, go home and park, measure the right amount of 2t from a 1L bottle of petron 2t, then dump it in the tank.
    Feb 2013
    #1054
    Thank you sir for the info!
    Jan 2010
    #1055
    Quote Originally Posted by cardict View Post
    2000 model sir, 13yrs in the service with 181+k in odo im using petron 2T premium JOSO FB+
    #1056
    not sure kung accurate pero naramdaman ko talaga yung difference..
    yes some say na walang top speed, or performance na pagbabago pero chineck ko using OBDII scanner..
    notice in the picture na naging 99 WHP siya after adding 2T.. ramdam after few KMS..
    by the way.. ang oto ko ay Hyundai Tucson JM 2.0 CRDi Turbo Intercooled
    Jul 2011
    #1057
    Ano yun tumaas HP pero bumaba TORQUE?
    Jul 2013
    #1058
    I just got my new 2013 Mitsubishi Strada GLX Non-VGT. Okay po ba maglagay ng 2T with this engine?
    Nov 2004
    #1059
    Banas na banas ako sir buong byahe from manila to sbma at buong stay sa subic gaspang manakbo at bitin hatak parang hirap turbo diesel pa yun, then pauwi after magpakarga diesel max lang with powerburn 2T oohyeah ang dulas talaga kinis manakbo at adik bumirit sa sctex, pansin ko din bagal bumaba ng fuel gauge, posible talaga tumipid dahil ramdam mo ganda sa takbo at di hirap makina.
    Sent from my ifive MINI 2 using Forum Runner
    #1060
    mabilis maubos Turbo Diesel. tried it sa FM before. Unioil diesel + 2T talaga pinaka ok if you ask me hehe
Diesel owners that add 2T oil to fuel
