Page 19 of 93 FirstFirst ... 91516171819202122232969 ... LastLast
Results 361 to 380 of 1853
    Jul 2011
    #361
    ganun ba? will do mamaya, thanks for the info jnala,, anyway, my ride is eagle bd25 nissan, serves me well and living up to my expectations, hope it gets better with the 2t magic, hehehe
    Jul 2011
    #362
    i noticed that shell 2t sx2 decarbonizer is fb rated? ok lang ba yon? nailagay ko sa tank, 250ml all in all, for 50 liters, naguguluhan lang ako kasi fb rating yon, ok lang ba yon kahit fb rating?
  3. #363
    It should be ok. Mas maganda lang daw effect ng FC (havent tried since FB lang readily available sa amin).
    Quote Originally Posted by pj3378 View Post
    Yup it's ok, yan pinapagamit ko sa mga truck since shell diesel naman din. Sabay na.
    Nov 2011
    #365
    Started using 2t jaso fb on my foton pick up and tank is almost finished. First observation was reduced smoke emission. No major improvements yet on my engine sound and vibration. maybe on my next fill up.
    Hoping for more improvements to come
    #366
    Is this ok? This is the only one they have at SM San Lazaro. Got myself a liter.
    Dec 2007
    #367
    Yes that is perfectly fine to use. I did not know you could get 2T in 4L containers, what's the price and the place.
    That's what I'm using sir Otep!
    Mahal nga lang compared sa FB 2t.
    Jan 2003
    #369
    I didn't know this too.
    Nov 2011
    #370
    265- 4liters/ near NCRPO - taguig.(going towards Jollibee)
    Jul 2011
    #371
    Quote Originally Posted by zecand View Post
    anu ito? PhP265 / 4L ang price? and what kind and brand of 2T?
    #372
    Clarification, I just bought a 1L bottle of Castrol Activ 2T. If they had it in 4L bottles, I'd probably get that one instead.
    I bought this from Sea Oil today at Php30.00/200ml. But it doesn't have any JASO markings or anything specific on the container. Even the website contains only this information:
    SEAOIL 2T Grand Prix is specifically developed for two-stroke gasoline engines mainly used in motorcycles and scooters. It suits many types of equipment used for mechanized farming, small and medium-sized motors, such as motor mower, motor cultivator, power chainsaw and other portable equipment.
    Typical Physical Properties Unit SAE30
    Density * 15.6 C kg/L 0.887
    Viscosity * 40 C cSt 95.00
    Viscosity * 100 C cSt 10.75
    Viscosity Index --- 96.00
    Flash Point, COC C 210.00
    Pour Point C -21.00
    Dec 2007
    #373
    After further research it really does not make much difference on what JASO rating you use on non-synthetic oils. Here's why, the FC is low ash oil meaning it has a lower Zinc content (zinc when burt makes ash) which can cause deposits in 2 stroke engines. Here's why it's not applical in the application were are using it for one is the compression ratio and combustion temps in a diesel engine and volume of air flow through the engine will push most the unburnt ash out through the exhaust and what is left out your exhaust and the oil will collect the rest.
    Here's the other kicker, Diesel oil already has a very high zinc content and is getting burnt in your combustion chamber thanks to that handy EGR and the breather hose that recirullates air back into your intake, If you don't have a oil catch can your already getting oil vapor back into the combustion chambers. So there is almost zero difference if your using 2T that is not FC because if you have a functional EGR system on your diesel or have not added a oil catch can, your still burning zinc and making ash. No harm no foul.
    Lastly the sheer act of burning diesel makes ash and soot, so it's a moot point, suprised my little brain did not wrap around this earlier
    If your running Synthetic oil then your still burning those same particles via the same method, But it would make no sence to use synthetic. Use the Cheapest 2T you can find because the results will be about the same.
  14. #374
    so regardless kung anu 2T binili mo, results will be the same.. scents nalang ba? kasi nakikita ko ibang 2t scented daw ayon sa label..
    btw.. on 2T na din ako sa carens.. diesel max+2T on 1L-5ml ratio muna, dati kasi shell fuel save kaya siguro di maganda manakbo.. mas mura pa din than using petron's turbo diesel.. tsaka medyo nag-smooth out na ang takbo after around 500kms of use, lesser soot pa sa tail pipe end..
    Thanks for the heads up! This will definitely save me almost 40% on 2T oil. hehe
    As sir Yummy said, scents na lang. Caltex smells good!
    Jul 2011
    #376
    ang ganda nito lower flash point pede i-match sa petron turbo diesel, masubukan kng ty doc otep, btw mabango ba scent nya?
    #377
    Yes mabango. But I haven't smelled the others.. hehehe.
  18. #378
    next ko nga matry to....
    #379
    Yesterday, i had my full tank sa unioil...first time for me kasi nakita ko mura compared sa big three...given that i forgot my shell 2t, i asked kung meron silang 2t...and yes they have at 27 pesos for 200ml...upon checking, mas cheapipay yung bottle, walang jaso rating pero lemon scent daw! i tried it nalang and so far, ok naman...havent tried smelling my fumes though...
    #380
    I'm using PTT Hi Speed (JASO FC and TISI 1040-2541) on my XTO's 4JA-1.
    I bought their 500ml for P70+.
    PTT Philippines Corporation
Diesel owners that add 2T oil to fuel
