Results 1,091 to 1,100 of 1853
- Nov 2010
- 236
July 28th, 2013 12:22 AM #1091try mo palinis ang intake mo sir(pulldown) kasama na dun ang linis ng egr...been doing these ever since every 20k km after cleaning replace also air filter and have a tambutcho cleaning/flushing... effective ito sa akin...,
been using 2t sa crosswind but sa 4jx1 hindi pa takot ako wala pa akong narinig na nag try na sa 4jx1(sana meron)...meron akong kakilala gumagamit ng petron fuel additives(dont know the name) yung tig 60 pesos per 100ml yata yun...less smoke daw and improve FC...
- Aug 2003
- 317
July 28th, 2013 08:36 PM #1092My source for the maximum fuel rail pressure during operation for the Mitsu VGT engine of 1800 bar and nonVGT of 1350 bar is the Mitsubishi Service Manual Viewer System, btw.
Since they are using the same fuel rail, we can say that yes the tolerance of the fuel rail is 1800 bar. The actual limit is 2210 bar, the pressure when the rail pressure limiter opens. Source: Denso HP3 service manual.
Bottomline, for Mitsu CRDIs, 2T is okay to use.
- Apr 2011
- 256
July 29th, 2013 02:09 AM #10933rd full tank ko na with shell 2t.
report ko lang
my average diesel top up would be 70Liters out of the 80Liters tank capacity
without 2t, average fuel consumption with my navara is 7.5km/L pure city driving
after 2t using mix of 5ml of 2t per 1L of diesel
1st full tank Phoenix Diesel = 8.79km/L
2nd full tank Caltex Diesel = 8.7km/L
am on my 3rd now, I did fill my tank with unioil's diesel. i'll report my FC with this brand after my next full tank
so far am happy with the results
- Jul 2007
- 88
July 31st, 2013 02:10 PM #1094Mga Bossing Isuzu problematic 4jx1 here, near empty fuel tank (nka-ilaw na warning) i put 500Php of Petron Diesel Max(Low Sulfur daw ito sabi sa website nila maybe below 500ppm) 40.00Php per Liter that time and with the Mileage of 110,000KM. na captured ang attention ko kasi sabi nila mawawala daw Vibration if you put 2T. By the way my 4jx1 already running 3 Injectors kaya malakas ang Vibration bumigay na ung isa nung nag-overheat last summer nung Holy Week. Well so far nabawasan ung Vibration and hindi na masyado Visible ung Black Smoke. Well i think it really works kasi sa Australia gumagamit din sila ng 2T kasi nga sobra Low sulfur sa kanila as in 10ppm i think kaya magaspang ang andar ng makina sa katagalan. Shell 2T with Decarbonizer pala ginamit ko so far every day ang pag gamit ko sa Trooper 4jx1 ko running 115,350KM as of now.
August 1st, 2013 08:14 PM #1095
Question about sa maintenance:
Tuwing kailan po papaltan ang fuel filter kapag diesel+2t user? Is there a specific pattern, like how many months or kms? Or by inspection lang? Salamat po.
- Nov 2009
- 3,484
August 2nd, 2013 12:56 AM #1096^ 2T oil does not foul diesel oil, they are both oil so they mixes well.
In some diesel forums, they say you can fill the tank with pure 2T and the engine will work normally..
Just follow the usual FF replacement interval as recommended by your dealer/ manual and you will be fine.
- Jul 2011
- 584
August 2nd, 2013 08:12 AM #1097sa crdi system para mas maganda proteksyon sa injectors ay secondary na fuel fillter system w/ water separator, high flow rate 30micron para sa water separation lang ang focus. ito sana gusto ko kaya lang madugo >10k sa berrima.
Sa pagpalit ng fuel filter kung element lang papalitan sir, kailangan maingat kayo, baka maka-introduce kayo ng dumi (micron size) sa injectors.
August 2nd, 2013 10:11 AM #1098
Regular replacing your fuel filter every 10,000km will do the job.. Oh & avoid flooded gas station
My concern is, do i still need to follow 200ml per 40L diesel in using euro2 diesels?
August 2nd, 2013 10:18 AM #1099
Sa unang gamit mo sir ng 2T, best to replace your fuel filter after a month of regular use of 2T. Sa fuel filter kasi mapupunta yung mga malilinis ng 2T from Tank-Fuel Line going to your FF. Then diesel purge naman para sa after FF to engine internals. Di mo kelangan gawin to lagi, sa simula lang para matanggal yung mga duming nalinis at na loosen ng 2T.
Sent from my iPad Mini using Tapatalk
August 3rd, 2013 11:44 PM #1100
I'm now joining the experience, top-up 45 liters kanina + 250ml 2T (1/8 pa kase tank) tapos ginawa kong calibration ng 2T eh yung lalagyan ng mouth wash.. Wala kase ako mahanap na ibang botelya sa garahe.. Hehehhe..
Petron diesel max + petron 2t powerburn jaso fb combo on my fieldmaster 2007 4m40.
Nun inabot ko sa pump attendant yung 2t eh i was surprised na di sya nagtanong bakit or ano yung ipapalagay ko, sabi lang nya "turbo booster toh sir noh".. I just smiled..
I feel less vibration and slight engine noise reduction, i dunno if its just a placebo excitement feeling.. Since sabi nga give it atleast 50kms to take effect, pero parang pag andar ko eh may pagbabago na... Hehehe.. I hope it would get better from here on..
Salamat sa thread na toh.. Thanks din kay sir halimaw for some personal tips..
More power diesel + 2t users! ;)
