Results 1,081 to 1,090 of 1853
- Jul 2011
- 584
July 24th, 2013 10:35 PM #1081old school diesel where not designed for this kind of fuel, thus elastomer seals will deteriorate over time and will cause leak. I think it already mentioned on this thread (not me)
the additives/chemicals they use and formulate biodiesel or FAME(Fatty acid methyl esters) is what the FIE manufacturers wants to know but unfortunately fuel industry will not divulge everything.
lubricity is not the main concern over fouling using biofuel, its what the other stuff like water, soaps, sodium, etc.
Sorry im not technically declined to discuss this things.
only want to share this, while researching for pre-filter to an innova diesel engine, if its beneficial or not; im encountered those research papers.
Maybe google will help you. search "denso study biodiesel injectors"
Im just want to point out be very choosy in fuel stations.
http://www.innospecinc.com/assets/_f...Injector_D.pdf 2011
http://www.biopowered.co.uk/download/FIEM.pdf 2000
http://www.globaldenso.com/en/topics...tion_paper.pdf 2012
Petron acknowlege some of the challenges for RA 9367: “Biofuels Act of 2006”
http://www.pecj.or.jp/japanese/overs...o_S_Toledo.pdf
July 24th, 2013 11:55 PM #1082
To clarify, using properly made biodiesel will only cause problems on diesel engined cars manufactured before 1993. Other than that, there should be no problem. In my post earlier, I was just stating that adding biodiesel increases the lubricity our diesel fuel. Therefore, increasing the blend from B2 to B10 would increase the lubricity. Anyway, here are some interesting links about the pros and cons of biodiesel.
http://www.biodiesel.org/docs/ffs-pe...patibility.pdf
Biodiesel Production : Alternative Fuels / Fuel - Pacific Biodiesel
Run Your Car On Bio-diesel - The Good And Bad Points Of Bio Fuel
Los Angeles Biodiesel-Coop » Biodiesel Information, Tips, Fuel, Conversion, Membership » Biodiesel FAQ
http://pubs.cas.psu.edu/freepubs/pdfs/uc204.pdf
Biodiesel Mythbuster 2.0: Twenty-Two Biodiesel Myths Dispelled - Gas 2
July 24th, 2013 11:56 PM #1083
July 25th, 2013 12:00 AM #1084
Biodiesel Mythbuster 2.0: Twenty-Two Biodiesel Myths Dispelled - Gas 2Last edited by falken; July 25th, 2013 at 12:19 AM.
July 25th, 2013 12:03 AM #1085
July 26th, 2013 11:18 AM #1086
Guys pwede po ba toh sa fieldmaster 2007, 4m40 engine.. And ano po recommended ratio? Ano mas advisable na diesel? Shell or petron? Wala po kase unioil dito.. Salamat po..
- Jul 2011
- 584
July 26th, 2013 12:01 PM #1087yung fuel station na wala flood prone area or elevated at madaming nagpapakarga tapos obserbahan mo ko ok yung karga ng station.
ako kasi Petron hanggat maaari, pero madalas doon sa PUJ discounted pump section ng mga independent fuel station para mura
- Jul 2013
- 5
July 27th, 2013 01:17 AM #1088just read this thread,,,my trooper 4jx1 is a smoke belcher....can 2t solve this problem?
- Nov 2009
- 3,484
July 27th, 2013 11:51 AM #1089
- Jul 2011
- 584
July 27th, 2013 12:42 PM #1090suggestion ko ay try it, pero di nito ma-solve lahat ng emission fault ng 4jx1.
Parang may bad reputaion yata yan, kahit sa club isuzu pag di ka mahusay sa maintenance sakit sa ulo, dapat may advil ka lagi sa bulsa para inumin
