Results 1,581 to 1,590 of 1853
- Sep 2014
- 34
September 15th, 2014 09:35 PM #1581
September 16th, 2014 02:13 PM #1582
Been using 2t for my fieldmaster 4m40 for 2years na.. Works really fine..
Recently nagpaemission ako, clocked-in a 0.3 score..
Wala din akong black smoke even on high revs.. Engine noise is significantly lower than a brand new fort / dmax (compared it side by side with my buddies that have new rides)
Plus, i get good compliments from other customers sa suking petron station to where i do maintenance.. Sariwang sariwa daw for being a 7-year old pajero..
Petron diesel max + petron powerburn 2t combo gamit ko.. Tried seaoil biodiesel + seaoil 2t, nahihinaan ako sa hatak pero mas tipid about 0.3-0.5L/km sa fc.. Balik petron na lang
Posted via Tsikot Mobile AppLast edited by romeocharlie; September 16th, 2014 at 02:20 PM.
- Apr 2012
- 5
September 22nd, 2014 02:56 PM #1583
Sir, does the 2T oil protect the SCV (Suction Control Valve) in my pump? I've been hearing a lot of stories that SCVs in my pickup model is less durable than later ones. I drive '08 Hilux 2.5 D4D with 2KD FTV engine.
I feel consistent jerk in the engine at 1,500 RPM, experienced stalling and loss of power. i'm currently running around 90,000 kms in my odometer.
I was advised to have my injectors and pump checked by Central Diesel since my ride did pass the Electronic Diagnostic. Did pay Php 1,200 for diagnostic but the problem was still unknown although now, i know that it's not electrical. Did DIY replacement of both air and fuel filter and everything is smoother now. I don't think i'll be replacing my injectors/pump anytime soon.
Later i'll try the 2T mix and see how it works.
Thank you!
- Sep 2014
- 1,530
September 22nd, 2014 10:10 PM #1584
- Apr 2012
- 3,469
- Jul 2008
- 935
September 28th, 2014 11:46 PM #1586Hi guys,
Pwede kaya sa Mazda CX5 (Gasoline) itong 2T? Nag-aalala lang ako baka may mga unforseen problems in the long run? If yes, what's the ratio?
Thanks
September 30th, 2014 03:50 PM #1587
been a 2t user since this thread started...katatapos lang emission testing ko at nasa 1.27 ang opacity. limit is 2.2 for turbo diesels.
mine is 4d56 turbo non-intercooled. last oil change prior to emission test is about 8k km ago....no minor tune up also. basta gamit lang ng gamit. wala ding oil catch can. di ko na din drinain yung water separator bago nagpaemission. basta kinarga ko na lang yung natirang 2t ko bago nagpaemission test at ayun pumasa naman...
September 30th, 2014 07:34 PM #1588
- Feb 2014
- 160
October 1st, 2014 04:09 AM #1589
- Apr 2012
- 5
October 3rd, 2014 06:32 PM #1590Good day mga Boss,
Just finished my first bottle (200ml) 2T. I'm highly recommending all diesel car owners (not sure with petrol) to add 2T. The constant shake that i was experiencing is now gone. I'm sure that it was coming from a clogged up injector. I'll share my experience in detail for those interested.
Problems:
Low idle
Loss of power (stalling at times)
Constant shake at 1,500 RPM (parked)
Initially had my pickup diagnosed at Central Diesel Q.Ave and the result was negative (no problem with electronic). Sir Jake was kind and honest enough to entertain my questions and explained what could possibly caused those problems. And he was right! Supply pump and injectors. Unfortunately i don't have the budget to have it serviced at Central so i decided to take my chances and do a DIY.
BASIC:
Replaced Air and Fuel filter elements purchased at WSL Auto Supply - Kamias. I know the owner so again, cheaper. :D Increase in acceleration on highway drive but all problems still manifests on idle and in traffic.
Did a DIY, looking for the MAF sensor that might caused the drop in idle. No MAF found but found the EGR that's dirtier than your browser's history. hahaha cleaned the EGR and Throttle body with electronic contact cleaner. Can't believe the carbon deposits in my EGR and intake manifold so i decided to blank my EGR right away! I also recommend blanking. BTW, i'll clean my intake manifold soon. Damn EGR will bring you headache in time!
Took the SCV valve out from the supply pump, cleaned using electronic contact cleaner bought at WSL Auto Supply. I do not suggest performing this since SCV valve is expensive (10,000 php - ebay). It worked for me but there's no guarantee that it will work for you. It's hard to explain the procedure into words but a little help from a friendly household item did the trick.
Now:
Idle is still the same (650 RPM - no A/C) but that does not affect me anymore since the vibration was VERY minimal now that i was adding 2T. Initially added 100ml 2T on a 1,000 php diesel (around 23L Shell V-power Nitro). Even before finishing my first 100 ml i already feel a slight change in my engine's performance. Second fill up was still the same only this time i went cheapskate with Shell Fuel Save Diesel. I'm half way now and the constant shake is almost gone.
Engines power is restored, stalling was gone and constant shake is fading away. I have no idea how much money i did save on this but thank you so much!!!
2T x EGR Blanking x Filter Elements x SCV rebuild saved me! I drive a 2008 Hilux MK6 2.5L D4D with 2KD-FTV engine.
For those cheapskates out there like me whose experiencing the same problem, i'll be entertaining questions regarding my DIY.Last edited by edansramos; October 3rd, 2014 at 06:47 PM. Reason: additional help
