Results 1,481 to 1,490 of 1853
- Jul 2011
- 584
April 13th, 2014 11:10 AM #1481pati gasoline boy pinatungan na yung presyo. Kasi karaniwan wala naman kasi resibo yan at pag ganyan di agad binibigay sa cashier, binubulsa muna nila. Ganyan pumitik yung naging kasamahan nung nagkwento saken. At meron pang isang raket yung mga gasoline boy lalo na sa mga babae, yung hindi ugaling tumingin sa pump kung nakarga lahat, binabawasan nila ng karga ito, eto malupit minsan ginawa kalahati lng kinarga at nauubusan sa daan yung babaeng nagpakarga.
Posted via Tsikot Mobile App
April 13th, 2014 03:35 PM #1482
April 13th, 2014 03:51 PM #1483
April 15th, 2014 04:32 PM #1484
- Aug 2013
- 475
April 15th, 2014 07:03 PM #1485
April 15th, 2014 07:23 PM #1486
Currently not using 2T sa recent full tank ko. Masasabi ko lang, iba yun may halong 2T yun sasakyan. Mas pino ang tunog ng makina nung may 2T ako.
April 16th, 2014 09:12 AM #1487
What would be the effect if you are adding 2T oil in every full tank but the oil that you are using has low TBN? Some might not be aware of this.
April 16th, 2014 02:54 PM #1488
April 16th, 2014 03:08 PM #1489
High TBN na gamit ko sir I switch to Top 1. But previously I have been using other branded oils which I know have low TBN. Wala kasi binaggit si sir dvldoc na dapat high TBN din ang oil na gamitin if adding 2T.
- Jul 2011
- 584
April 16th, 2014 09:39 PM #1490Simple lang effect longer oil change interval.
Combating harmful effects of sulfuric acid.
Blanking or blocking EGR on crdi engines is another way to reduce effect of sulfur to introduce in combustion chamber, where soot, unburnt fuel high in
sulfur(when specially adding 2T) recirculated to the intake, detrimental to piston rings and other that may corrode with acid.
1:300 instead of 1:200 is what I found optimal to our innova.
or 1L(diesel) : 3mL(2T)
HTH
Mazda 3 is incredibly tempting, unfortunately the hybrid is not included in the coding exemption...
All New Toyota Corolla Cross
