2D Max...
Have your injection pump checked. I suspect that you have a damaged/worn out oil seal and/or drive shaft in your pump. What is happening is...oil coming out in front of your pump going to your timing gears and crankshaft thus increasing your oil level. When your oil becomes diluted, lubricity will deteriorate (it will not be sufficient to lubricste internal engine components) and can cause major engine failure. Better safe than sorry...so have it checked ASAP
11Likes
LinkBack URL
About LinkBacks
that's also what I thought because I really don't want to touch anything in the engine yet. it's just a couple months newly installed. hindi pa nga na submit yung change engine papers sa LTO eh.
Bookmarks
