Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Engine and Fuel System Talk Thread, Diesel Fuel Injection System Help Desk in The Workshop; I would like to help! Throw in your questions regarding problems with your fuel systems (injection pumps/ injectors/ turbochargers/ electronic ...
Page 1 of 202 123451151101 ... LastLast
Results 1 to 10 of 2015
Like Tree11Likes
Thread: Diesel Fuel Injection System Help Desk
  1. #1
    Join Date
    Sep 2006
    Location
    Quezon City
    Default Diesel Fuel Injection System Help Desk
    I would like to help! Throw in your questions regarding problems with your fuel systems (injection pumps/ injectors/ turbochargers/ electronic systems/ etc.....) Then you guys take it from there...................if I can be of help, why not!
  2. #2
    Tsikot Member Rank 4 rion's Avatar
    Join Date
    Default Re: Diesel Fuel Injection System Help Desk
    Dieseldude, how will I know if a Turbo is Watercooled or Oilcooled? and can one install a watercooled turbo with an oilcooler? and how?
  3. #3
    Join Date
    Sep 2006
    Location
    Quezon City
    Hi Rion,
    All turbos are cooled and lubricated by the engine's lube oil. Aside from oil supply and drain lines, a water cooled turbo will have coolant supply and drain lines as well. Plumbing will often be attached to the center housing, near the oil lines. On high load applications, coolant is sometimes plumbed to the turbine housing, and the turbine housing will have the necessary fittings.
    You don't have to install an oil cooler.
    An air intercooler may help. This is located between the turbo's air discharge duct and the engine's air intake manifold.
    I hope I have been of help to you. Good luck.
  4. #4
    Tsikot Member Rank 2 Boy Torotot's Avatar
    Join Date
    Apr 2005
    Hi Dieseldude,
    I'll repost a hanging question i have on the other thread regarding preventing fuel injection problem, specific on the Patrol GU:
    Quote Originally Posted by Boy Torotot View Post
    So any other tips to help avoid this fuel injection problem in the future? Here are some of the suggestions deduced from above posts:
    1) regularly change fuel filters
    2) fill up only in stations known for their clean fuel
    3) do not install any fuel saving device
    4) sell your patrol
    Anything else? How about using Biodiesel, could this cause fuel injection problem?
  5. #5
    Join Date
    Sep 2006
    Location
    Quezon City
    Hi Boy Torotot,
    Check out my comments posted under the "Home-made Biodiesel"thread which I posted last September 24.
    Your suggestions are OK, but I would like to add that when you replace your Fuel filters go for the Original (critical for this new models) not the replacement filters.. I am not selling for Nissan, but I have seen quite a number of problems when a replacement brand is used. Why scrimp on the cost when you do not spend this kind of money everyday for your vehicle!
  6. #6
    Join Date
    Apr 2005
    Thanks sir! Will check your comments right away.
    I've been using the original fuel filters, and having it replace regularly at the casa, since i got my ride. So they should be using original filters and not replacements.
  7. #7
    Join Date
    Quote Originally Posted by Dieseldude View Post
    does it mean that my turbo is both Watercooled and Aircooled. may IN-OUT kasi yung water and oil paths sa Turbo...
    and does it need a turbo timer?
    thanks, may spare toyota 3c-tdi engine kasi kami, baka puwede ilagay sa aming 3c-td. hehe..
  8. #8
    UST ENT-HNS OTEP's Avatar
    Join Date
    Location
    Apalit, Banawe, Bulacan
    Oil is primarily for lubrication, water is primarily for cooling.
  9. #9
    Join Date
    I'm still a bit confused sir Otep, other peeps differentiate the two... is there a Watercooled Turbo only and an Oilcooled only?
  10. #10
    Join Date
    Sep 2006
    Location
    Quezon City
    Quote Originally Posted by rion View Post
    If your turbo has oil and coolant plumbing, it is oil and water cooled. Oil primarily lubricates the turbo. Oil has a secondary function of cooling the turbo as heat energy is transferred to the oil, and further dissipated to the engine. Water cooling is sometimes integrated into the turbo design if it is expected to be used on high hp engines (more hp = more fuel = more heat).
    A turbo timer may help. However, if the original design doesn't have it, you don't really need it. So why spend more?
    Pwede rin if you want to try.
Receive Latest Car Engine and Tuning Listings Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Engine and Tuning Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
