Results 2,131 to 2,140 of 2348
- Sep 2006
- 1,335
September 17th, 2014 08:57 AM #2131
- Sep 2006
- 1,335
September 17th, 2014 08:59 AM #2132
- Sep 2006
- 1,335
September 17th, 2014 05:47 PM #2133
- Aug 2014
- 391
October 15th, 2014 10:29 PM #2134Hi Tsikoters,
nakapunta ako onetime sa isang calibration center (davao), then pinatingnan ko sa expert nila kung dapat bang calibrate na injector ko, xtrm 2000, 4ja1. Sabi nya, ok pa naman, pero medyo not that good na kasi sa FC, so sabi nya pwede ma replace yung nozzle, gawing medyo matipid yung buga ng fuel.... ano kaya maging epekto if gawin yun? di kaya mawalan ng konting power? though im sure, may chance na gaganda ang FC. Please advice naman sa mga nakagawa na nito.. medyo mahal din yung per nozzle, 1.5K each daw.
tia
- Oct 2014
- 11
October 19th, 2014 02:02 AM #2135Hi. how do you check your turbocharger if it's still working fine or not? My crdi engine is running pretty slow and black smoke from the exhaust. When I floor it wala ako nararamdaman na boost from the turbo unlike before. The engine makes a whizzing sound na parang dynamo. Is there an easy do it yourself way of checking out if the turbo is working fine?
- Jan 2010
- 2
October 20th, 2014 03:16 PM #2136Please disregard this post.
- Jan 2010
- 2
October 20th, 2014 03:16 PM #2137Hi DD,
First thanks for sharing your knowledge on the subject via this thread. Would like your advice and help please. Starex 2001 with D4BH engine sasakyan ko. Overhauled engine (total) last September 2011 and all was well until 2 weeks ago. Ayaw na humatak, at napaka usok pag binibirit ko. Dinala ko sa injection pump (IP) shop, kailangan daw overhaul IP at fuel delivery problema (no idea what this means). Mas mabuti ba ipa overhaul ko IP, ako bibili piyesa o kuha na lang ako surplus na IP. Brand new is out of the question luma na masyado sasakyan tingin ko hindi na sulit bilhan ng bago (ibig sabihin nagtitipid ako). Baka meron ka alam na mapagkakatiwalaan source ng surplus? Thanks in advance and more power.
- Apr 2010
- 739
October 20th, 2014 09:40 PM #2138Hi DD,
I see a small wiff of black smoke sa startup pero nawawala naman agad. Even when I drive hard halos walang visible black smoke. Dati kasi sa startup parang wala naman (or di ko lang napapansin). Normal lang ba ito?
Parang may kalakasan na rin sa FC, I get 7km/L in moderate to heavy traffic around Manila. I think di pa nase-servican ang injection pump / nozzles neto. Will cleaning improve my FC? Advisable bang i-lean ang fuel delivery? BTW fuel filter is wayyyy due for replacement na, still finding OEM kasi but will VIC do the job?
Ride pala is a Terrano TD27T SUVic A/T. Many thanks!
October 27th, 2014 03:02 PM #2139
Sir, hindi ko po alam kung tama ang napasukan kong thread.
Ask lang po, pag nagpaFull tank po kasi ako sa gasoline station, nakaka-ilang click yung nozzle bago mapuno talaga. Kita mo na halos puno na talaga ng fuel tapos maya maya bababa na yung fuel, eh d fill na ulit yung gas boy tapos magclick na naman yung nozzle tapos bababa ulit ang fuel. Normal lang po ba ang ganito? Thanks po.
BTW, 2014 Hyundai Accent Hatch CRDI po ito.
- Aug 2014
- 391
October 31st, 2014 02:21 PM #2140tapos magclick na naman yung nozzle tapos bababa ulit ang fuel
you mean, parang na consume yung fuel pero naka park at nag kakarga pa naman ng fuel ang gas boy?
imposible namang butas. Eh umabot ka ba na na full tank na or di talaga nag full?
alas, much as we might want to rely on our noses, we may not use our noses to do emissions...
LTO accredited emission testing centers
