Page 4 of 4 FirstFirst 1234
Results 61 to 68 of 68
    Nov 2007
    how much per liter yung delo gold multigrade? san po kayo nag pa change oil? any feedbacks regarding the engine oil?
    Jan 2009
    Delo Gold is P200 kung per liter, pero baka mas mura yung 1 gallon na (4 liters) ang laman, gud na ito sa pa change oil mo. 4 liters lang nid nang crosswind.
    i also have a Frontier 4x4 and use synthetic oil with it with no probs...
    it is the Patrol that i'm concerned about since the manual clearly states that synth oil as well as oils having API ratings above CF-4 is prohibited...
    Just use the Shell Helix Diesel Super or the Mobil Super XHP. Any of them mets the requirements ot Nissan for your Patrol.
    I have emailed SeaOil regarding the technical specs of their CI-4 oil. I'll post the data once they replied. So far the Frontier 4x4 of my brother runs smoothly with the new oil. We also tried the oil in our Trooper.
    Dec 2002
    For discussion's sake:
    Diesel engines produce more carbon, soot than gasoline engines by their design. Their oils too are different since diesel oils have to contain the abrasive carbon til it reaches the filter- thus more detergents in diesel oils.
    So why would a new nissan engine (with common rail, EGR) specify a lower API rating to the point of using oils primarily designed for gas engines? The TBN in gas oils are much lower, therefore easily depleted when used with high sulfur diesel fuels. The lack of TBN would lead to higher acidity in the oil which could lead to a shorter engine life.
    On oil prices:
    It's possible that Shell Helix diesel was first designed as a gasoline oil then broadly priced as a diesel too- but only spec'd at CF. The Rimula line was meant for diesels and priced as one.
    Tingin ko kaya CF requirement ng Patrol ay dahil sa high sulfur content ng diesel fuels natin to counteract the high acids that come with it. They may rvise it with the lowering of the sulfur by Nov.
    Jul 2003
    sir chieffy : medyo contrasting po ata ang opinion nyo ni sir jackaroo? Medyo nalilito ata uli ako.
Which Diesel Engine Oil...
