Results 1 to 18 of 18
    Jun 2012
    Im new here and needs help. I got a second hand car, Toyota Vios 2006 1.3J. After two weeks on every engine start, the check engine light was light ON the dash board. Here to ask what is the best thing to handle this.
    Maraming Salamat! thanks in advance.
    Too difficult to do an exact pinpoint based on the information we know.
    But in my opinion, if a 5-6 year old car is giving you a check engine light (CEL), I'd have Toyota check it because it can't be good - spotty service records on the warranty/service booklet will confirm if the previous owner was lazy with the maintenance. Who knows what else is just about ready to break?
    I'll have Toyota do all necessary preventive maintenance and repairs so you can start anew with the car (kahit sa labas mo na ipa-maintain afterwards).
    Change oil ka muna then observe
    may napansin ka ba na kakaiba pag naka-idle ang auto mo? like nangangatog or parang mamamatayan ka? try mo check yung spark plugs, tension wires and sensors...
    pero syempre mas ok pa din na dalhin mo sa casa or sa mas may nakakaalam...
    Or pwede rin nga yun spark plugs palit ka na rin... Sana makuha Sa change oil and plugs Teka Lang meron pa plugs ang vios? Ano bang kotse yun with 6 or 8 s plugs na kotse?
    Off topic
    Sa favorite brand mo yan sir shadow. Yung mga I-DSI variants. 2plugs / cyl
    honda city yata sir yung may 8 plugs...
    Jan 2008
    naka sakay ako ng taxi lately.. vios. naka on yung CEL nya... takbo pa din...
    Jun 2012
    Thanks for quick reply. This what Iam also thinking, to bring the car to Toyota service center. Unfortunately the service/warranty booklet was not turnover to me. This is a company car that just turnover to me. Previous owner already went abroad. and im the one who shoulders maintenance.
    Jun 2012
    Yes. tumatakbo naman..no weird sounds heard at the engine. even changing gears.
    Jun 2012
    at times meron nga ganto. namamatayan
    Quote Originally Posted by cvvrvv View Post
    The Toyota service centers should have records of your car's previous service history, assuming it was ever serviced at any Toyota casa.
    I guess that should be your first stop - both to fix the CEL problem and any other things that may need fixing (but aren't readily apparent at this point).
    Jun 2012
    Thanks for your advice. Yes i will. Thanks!!
    i often have this problem with my Civic 99 (probably 2-3 times a year). I really dont know whats causing this, and since i just have the car maintained at my friendly talyer, they dont have the tools to diagnose this. What I usually do is i just pull over, stop the engine, re-start and it goes away. So far the engine is still very good. KEep us updated on your progress bro.
    Jan 2009
    A lit CEL is almost certainly a problem with the vehicle emissions system. But a diagnostic tool would be able to provide a bit more perspective as to what is going on by listing the DTC(s) that triggered the CEL.
    *poorprince: sir, for civic 99, puwede po ata makuha yung error code through blink codes. may connector na shoshort sa ecu at bibilangin yung blinks ng check engine light.
    hth.
    QUOTE=poorprince;1948522]i often have this problem with my Civic 99 (probably 2-3 times a year). I really dont know whats causing this,
    and since i just have the car maintained at my friendly talyer, they dont have the tools to diagnose this. What I usually do is i just pull over, stop the engine, re-start and it goes away. So far the engine is still very good. KEep us updated on your progress bro.[/QUOTE]
    Apr 2009
    If your malfunction indicator lamp lights up as "CHECK ENG", it usually points to the emission system and this warrants an engine scan in the casa or special auto repair shops to pin point where in the emission system is defective. In most cases the sensors are the ones at fault. The most common emission sensor that lights up the "CHECK ENG" is the MAF (mass airflow) sensor or in other engines the MAP (manifold absolute pressure) sensor. Other sensors that can light up the CEL are the oxygen sensor, TPS (throttle position sensor), IACV (idle-air control valve) and the EGR valve. others are too minor to mention like a leak in the vacuum hoses of the throttle body going to the MAP sensor. The engine scan (MUT -multi use tester) will narrow down and pinpoint the defective sensor as well as erase the error codes in your car's ECU. Illuminated CEL will not leave you stranded on the road but will affect your fuel consumption drastically. If you cannot have your car undergo an engine scan yet, you can have your MAF sensor cleaned sparingly with an electronics contact cleaner. Disconnect your battery while cleaning your MAF sensor..If after cleaning your MAF sensor removes your illuminated CEL, then your MAF sensor is just dirty and cannot do its job. But if the CEL does not disappear after cleaning your MAF sensor, the MAF sensor must then be defective and needs replacement or there are other problem in the emission system. This is where the Engine Scan now becomes very useful...
    Dec 2010
    check engine is a malfunction indicator light. may na dedetect ang computer na abnormalities sa system kaya nailaw yan. pa scan nyo po para malaman nyo po ang trouble codes na ibibigay nya. pa print nyo din po yung freeze frame data para malaman nyo po kung paano at kailan lumabas ang trouble code na madedetect ng scanner.
Check engine steady display
