Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Dec 2004
    I used to start the car immediately, once I've inserted the key in the ignition. But a friend told me that it's bad practice. Kailangan daw hintayin ko muna mamatay yung check engine light bago mag-start. Totoo ba to?
    If yes, what are the probable effects on the engine if i start too early?
    Feb 2009
    Quote Originally Posted by blkcoffee View Post
    what bible has he been reading?. i have worked on cars for a long long time and read owner;s manual to owner's manual and i'm sorry i must have missed that. i have never seen what he told you.
    Feb 2009
    which bible has your friend been reading? i have been in the industry for many many years and this is the first time i heard this. some cars will not extinguish the check engine light even if you turn blue until you start the car
    Jan 2009
    When you turn on the ignition, the computer runs a diagnostics of itself and of selected sensors. If everything passed the test, the CEL is extinguished. Depending on the car, diagnostics can last 5-20 seconds. Starting the car immediately does not terminate the diagnostics. The makers probably thought that once the engine caught on, it would be wise to extinguish the CEL to alleviate any confusion that there is something wrong with the engine. The ECM/PCM runs several tests every second so if there is indeed a problem, the CEL will light up in real time.
    Among other things, the warning lights are all initially lit up to show that all of them are working.
    Jun 2008
    Ano pong sasakyan ito?
    Sorry hindi pa kasi ako nakaranas na may "check engine light" pag nag engine start eh. Kadalasan ay ang seat belt warning indicator ang umiilaw kasabay ng warning sound. Ito siguro ang sinasabi ng kaibigan mo. Actually noong nag bibigay ng orientation ang SA ng irelease ang Honda city namin ay ito ang sinabi: "wait nyo po muna mag stop ang alarm sound before turning to ignition". Mali yata ang pagkaintindi nya kasi seat belt naman yon. Pag nag-strap ka ng seat belt before inserting the key ay wala kang maririnig na warning sound.
    Jan 2009
    Quote Originally Posted by weisshorn View Post
    Another myth. That's not true. The beeping is just a reminder to wear the seatbelts. On some cars, the warning beeps are repeated every several seconds if you drive the car without still wearing your seatbelts. The beeping is sometimes made to be annoying so the driver is forced to wear the safety belt.
    You can start the car even in the midst of the beeps without any problems.
    Nov 2007
    on some cars, hindi nawawala yung CEL until you start the engine. On other cars, particularly hondas, the CEL stays on for around 3 seconds before it goes off. I sometimes wait for it to go off before starting, and sometimes i dont. I dont see a difference naman whether i wait or not.
    The beeping sound is just the seatbelt reminder buzzer. It doesnt matter naman and you dont have to wait for it to stop before starting the car.
    Heard this also to other car owner specially with EFI engine . There is no harm in trying even its a myth.
    Dec 2009
    I was told the same.
    Now i dont have to wait 3-5 secs before i start my car
    Apr 2009
    My rides ganito ang CEL upon starting.
    02 Adventure - CEL goes out after 3-4 seconds, before starting, palagi ko itong hinihintay mawala before starting until I bought my Alto.
    08 Alto - CEL ay hindi nawawala hanggang hindi iniistart. hinintay ko ito for 10 seconds or more pa yata, wala pa rin nangyari dahil nasanay nga ako sa Adventure ko na hinihintay ko pang mawala. After that, nalaman ko na hindi na pala kailangan hintayin na mawala ang CEL.
    Hope naliwanagan ang iba. It really depends on the car.
    Apr 2009
    ganuon rin sabi ng kaibigan ko na nakalancer, kaso sa sentra hindi nawawala ang ilaw mga ilaw sa dash, ang mawawala lang pag nag hintay ka eh ang tunog ng fuel pump hwiiiiiiiiiiiii tokok ehehehe
    hindi applicable ito sa mga sentras, dahil hindi namamatay yung CEL nila.
    dun sa sentra ko, inaantay ko lang mawala yung parang hissing sound bago mag start, normally takes around 3 seconds.
    Although, wala namang problem if you start the engine agad. Ako naman, naging habit ko lang to wait na mawala yung CEL to complete yung test & to see right away if may problem bago ko start yung engine. btw, i'm using Honda Civic. yung CEL nawawala after 3-5 secs.
    Jan 2009
    '06 and up Civics will take like 20 or so seconds before the CEL goes out.
    Apr 2009
    kung hihintayin mo ito.. hmmm.. mas maigsi lifespan ng battery? not sure hehe.
    Jan 2009
    Quote Originally Posted by p_borj View Post
    Nope. Sayang lang oras kung maghihintay ka.
    Sep 2006
    honda civics usually ganyan hissing sound pag ka on then check engine light goes off in 3 secs after the diags
    Jan 2009
    Quote Originally Posted by MasterZerg View Post
    Fuel pump. 2 secs on 06 and up Civics. We had a 92 Sentra ECCS before and it also charges the fuel line for a couple of seconds when you turn on the ignition.
    Sep 2006
    I guess for TS .. yes or no lang ang sagot sa tanong nya.. ako gusto ko din malaman e napagisip ako ahihihihi
    Oct 2009
    just to revive this thread, because I was also told to wait for the CEL to turn off before starting the engine and have been doing it ever since but having to wait for 5secs. is long if you're just staring at the dashboard, which most of the time annoys me. so guys can we have a final verdict: HINTAYIN OR OK LANG WAG HINTAYIN mag-off ang CEL?
Check Engine Light- Hintayain Mamatay?
