Results 1 to 20 of 45
    Oct 2009
    My Honda ESI wont start unless CEL turns off, yes for honda ESI its normal. But my problem is it takes time during rainy season pag malamig makina specially in morning. would take 5-10minutes before it turns off. I went to a service center somewhere in banawe earlier to have my Computer Box scanned for P1200, But I didn't paid it though dahil wala naman na detect na problema, they checked next is the main relay sabi nung mekaniko ok pa naman daw but still when my car gets cold again it will take time nanaman. I ended up leaving the place coz they might just ask a lot from me hindi naman daw nila kaya gawin yung kotse, they need to check eveything and it will take time. so habang wala pa kong binabayaran umalis na ko haha.
    help sa mga naka experience the same problem. What could be the culprit? and please any recommended electricians or mechanics? I'm just student so i really watch my budget buti naka free check ako dun sa pinuntahan ko kanina
    thanks tsikot.
    how about kung nakastart na makina? may CEL read pa rin?
    EDIT: guesstimate ko ecu yan.
    Oct 2009
    Quote Originally Posted by archie123456789 View Post
    nope. pag on goin na makina wala ng CEL, just by turning it on it takes a lot of time before mawala yung CEL. I had them opened & checked my ECU. wala naman daw sunog, and i asked them if how will they figured out if my ECU is damaged. They said that they dont know how to check it. So saan ko ba dadalin na kaya tumingin at mag repair ng ECU? and do I have to consider other possible parts as well before dealing in my ECU?
    help please.
    actually kaya mo DIY yan kung may multi tester ka. kailangan mo lang malaman kung may dumadaloy sa mga capacitor, resistor etc. na koryente. tingin ko IC may tama sir. pwede naman rechip just in case.
    kasi kung walang naread na problem obd, ecu ang ayaw magbato ng signal.
    electrician sir ang kailangan. try reys electrical sa may cubao.
    Oct 2009
    sir napa check ko na and na replace yung capacitor na corroded, wala namang pagbabago still an tagal pa din mawala ng CEL ko during cold start. chineck din nila yung sensors for temperature ganun pa din.
    thats a cheap fix sa ecu.
    EDIT: ay sorry sir hindi ko napansin ayaw pala start kung may CEL pa. anyway may redondo or crank ba kung try mo start na nakaON CEL?
    Feb 2009
    Quote Originally Posted by tonzi View Post
    thanks tsikot.
    please identify the model year, engine size and engine family (nomeclature). will check for pending technical service bulletin or recalls for this specific vehicle
    Jan 2011
    Model : 95 Honda Civic ESi
    Engine : PH16 non vtec
    Oct 2009
    ESI 93
    PH16
    efi
    Quote Originally Posted by r1chm0nd View Post
    Hala sir.. anong nangyari? busted fuel pump? is the car still running? Where did you bring your car sir?
    along del monte sir, near talayan village
    i think it means na hindi na nawawala yung CEL para start yung engine. kung fuel pump may problem dapat hindi na talaga tumakbo yung oto.
    yup hindi na nawala yung CEL ewan ko anu ginawa ng mekaniko dun iniwan ko yung oto dun. bukas ko pa babalikan sana maayos na. na diskarga na nga battery ko kakantay na mawala yung CEL. di na tlga nawala.
    now thats bad... paano nasabi fuel pump sira?
    Oct 2009
    hindi naman sinabi fuel pump ang sira.. need lang marining na gumagana yung fuel pump first before mawala yung CEL yun kasi indication bago mawala yung CEL..
    sana may mekaniko na maka basa ng thread ko hehe.
    kasi kung fuel pump ayaw gumana dapat nabasa yun ng check engine. usually fault 43 lalabas. since wala naman naread dati, medyo malabo.
    tancha ko ayaw magbato ng signal ng ecu talaga or in other words IC.
CEL doesn't turn off, during COLD SEASON
