Results 1 to 10 of 17
- Jan 2011
- 262
June 12th, 2011 11:14 PM #1Good evening gurus.. I hope you can give me some inputs based on what I am experiencing with my car. Sometimes, the temperature gauge is just above the midway point (As in a line or two after the halfway mark), I just ignore it then after some time it will go down below the halfway mark.
There's no specific time in which this happens. I don't know if this is already considered as overheating.. what do you guys think? TIA!
Edit : BTW my car is 95 EG
June 12th, 2011 11:17 PM #2
not yet overheating. what are the symptoms sir? loosing water, power lost, running on high rev?
- Jan 2011
- 262
June 12th, 2011 11:33 PM #3Losing water sa reservoir tank sir, pero minimal lang.. After around 100km trip nababawasan na. What I do is every trip, I refill the reserve tank with water na lang.
How will I know if I'm already overheating? No power loss naman and I stay on 1.5K to 2K rpm sir.. Thanks for the quick reply, kala ko overheat na agad yun.. I believe I'm drinking too much coffee hehehe!!
June 12th, 2011 11:39 PM #4
may leak sir. anyway yung up and down ba ng temp ay kung aandar yung rad fan?
overheat kung lagpas ka na 3/4 sa temp
- Jan 2011
- 262
June 12th, 2011 11:50 PM #5Sir I don't know if tumataas ung temp pag hindi umaandar yung rad fan.. Kasi it happens after driving for some time eh..
I already had my radiator overhauled, lower rad hose replaced. My upper rad hose is still okay daw. I noticed lang that my rad cap have a slight "punit"..? Diba may goma yun na paikot sa baba ng spring? May konting punit doon sir.. Dun kaya ung fault?
June 13th, 2011 12:02 AM #6
i think theres the fault. baka escaping water na if the water in the rad is hot enough. try replacing that first and see what happens.
June 13th, 2011 12:07 AM #7
sa older cars, ang temp needle ay typically nasa malapit sa lowest.
sa mas bagu-bagong mga sasakyan, typically nasa middle (typical na puwesto). as long na hindi tumataas more than the middle, malamang ok iyan.
wait tayo sa mga may same model ng car mo.
- Jan 2011
- 262
June 13th, 2011 12:12 AM #8
- Jan 2011
- 262
June 13th, 2011 12:22 AM #10
high idle RPM at engine start
