Results 1 to 10 of 16
April 19th, 2013 11:16 PM #1
Guys need help, what could be the possible reason why my battery won't hold charge despite na bagong gawa na ang alternator (then pina-check ko ulit sa ibang auto electrical specialist shop, wala naman daw problema at maganda rin naman daw yung pagkakagawa nung previous shop na pinuntahan ko), and my battery is Motolite Enduro 1snf -- 5 mos. old pa lang. malakas naman siya yun nga lang after a minutes or hours of driving na-ddrain/didischarge siya, since bukas lahat ng accessories ko like aux fan, aircon & stereo kaya after use e, sinasalang ko siya sa isang sasakyan ko para magkarga ulit. btw, Toyota Corolla XE (2e Engine)
April 20th, 2013 06:47 AM #2
April 20th, 2013 07:39 AM #3
baka po loose battery cable.... or , hindi kaya ng alternator nyo ang power load... or most probably battery po ang problema....
pa load test nyo sa suking battery shop...
April 20th, 2013 07:55 AM #4
Soli mo sa motolite? They can check for parasitic load on site. Dati, sira talaga battery and they replace ours for free.
- 52,701
April 20th, 2013 07:50 PM #5na-didischarge ang battery mo habang nag-da-drive??!! baka electrical connections yan.. baka hindi uma-abot ang alternator electricity sa battery dahil sa bad connection..
but that should be easy to check.. bring to a qualified auto electrician.. bring to motolite outlet. they'll do the checking right, because it may save them the cost of giving you a new battery.. heh heh.
April 20th, 2013 11:30 PM #6
Try mo check yung battery clamps. Malamang maluwag na kaya hindi nagchacharge ng maayos. Happened to my beloved Lancer.
April 21st, 2013 08:29 PM #7
It appears that the alternator is not charging the battery.....
Nor supplying the vehicle...
18.8k:dance1:
- Sep 2006
- 84
April 21st, 2013 10:05 PM #8To check if the alternator is charging the battery:
- start the engine
- disconnect either the negative or positive battery terminal
If the engine dies..the alternator is not charging
April 21st, 2013 10:33 PM #9
nag iingay ba sasakyan? baka nag slip ang alternator pulley kaya hindi na chcharge. kahit sira baterya mo, basta okay alternator walang problema dapat. problema mo lang hindi mo ma start sasakyan pag sira baterya that won't hold charge.
April 22nd, 2013 05:54 PM #10
pls wag na ho tayo mag advise ng tangggal baterya habang umaandar, it could do more harm than good
