Page 1 of 20 1234511 ... LastLast
Results 1 to 20 of 383
    Aug 2012
    help. can anyone suggest a smart, fully automatic car battery charger?
    - can charge the battery without removal from the engine bay
    - must be able to switch to "trickle charge" mode when battery is fully charged
    - can kept plugged into the AC outlet for a long time (24 hours or more) without damaging the car battery
    - must support maintenance-free batteries among others
    - have safety provisions, e.g. over-current, over-power, over-voltage, over-charge, etc.
    please share brand, model, price and store/seller where you got it.
    Feb 2014
    imax b6 hobby charger. i have this model. very useful. i once didn't run my car for 2 months. this thing charged it right up
    also charges r/c batteries. lithium ion flashlight batteries. NiMH. NiCd. LiFePO4
    very useful to have. try the local r/c shops
    Aug 2012
    *Vodka: looks like the IMAX B6 is primarily intended for R/C batteries. i need a charger specifically designed for car batteries. thanks for the suggestion.
    Aug 2012
    any user of deca (Italy) SM-1270 automatic car charger here?
    Deca SM-1270
    Apr 2010
    How much do these things cost? I bought a manual car battery charger (Panther) kasi I have a feeling that a good manual charger outlasts a cheap 'smart' charger within its price range (2k)
    Aug 2012
    price based on *******
    deca (Italy) SM1270 = P5,999
    deca (Italy) SM1115 = P6,999
    Suder (China) SON-20A = P2,200
    yung deca brand is legit and has full info on their website Deca s.p.a.
    Aug 2012
    looks like the deca (Italy) SM1270 has what i am looking for..
    Features:
    - Automatic battery chargers with program for charge conservation (pulse recharge).
    - Suitable for charging lead batteries: WET serviceable and maintenance free, AGM, GEL, Ca/Ca.
    - Multi step charging
    - The batteries are charged by applying sophisticated multi-step programs.
    - High efficency
    - "I-U" Charging characteristic (constant current - constant voltage) minimizes battery charging time.
    - Maintenance Function "Pulse Maintenance"
    - Can remain connected to the battery for a long time.
    - Keeps the battery ready for use through the pulse charge.
    - Refresh function "Recond Battery"
    - Regenerate batteries that have underdone heavy discharge cycles (SM1270)
    - Safety guaranteed
    - Designed to protect vehicle electronics. Non-sparking.
    - Reverse polarity protected and short-circuit proof.
    - IP65
    - Lightweight and compact battery charger. Built for outdoor use.
    Specification:
    Input Voltage (Volt 50-60Hz AC): 1 Ph x 230
    Power (W): 130
    Nominal battery voltage (Volt): 12
    Voltage limitation (Volt): 14.4 - 14.7
    Average charging current (Amp): 7
    Charge Programs: 4
    Battery types: Pb: WET MF, GEL, AGM, Ca-Ca
    Battery capacity (Ah min/max): 14 - 150
    Dimensions (mm.): 202 x 90 x 45
    Apr 2010
    Quote Originally Posted by red_one View Post
    Was initially eyeing that Suder pero am having reservations sa quality especially sa connectors pa lang. Mukhang mas malaki pa yung Panther ko na 6A kesa sa Suder 20A hehe. Ask ko lang if you have a vehicle fleet? With that price kasi its a brand new battery na basically
    Aug 2012
    *ParticleX: no, i only have 1 car. pero tama ka, price of brand new battery na nga.
    about panther manual battery charger, paano paggamit nyan? pwede ba iwan nakakabit sa battery at AC power for 24 hours and more, without damaging the battery?
    hindi kasi magagamit ang car for 1-3 months so ipapakabit ko lang sa kapatid ko ung charger sa car battery.. like every 2 weeks or 4 weeks for maintenance charging. dapat safe na pwede iwan nakakabit para kahit makalimutan at kinabukasan pa tanggalin ang charger ay okay lang.
    Apr 2010
    Yung binili ko is Panther PBC-6A. bale manual-based charging sya. May time table nakalagay kung ilang hours estimated charge kung fully depleted battery. Ang ginagawa ko is to open the battery vent caps and add water, and charge it. Pag 1A or less ang nakalagay sa ammeter (built in sa device) almost full charge na yun. I also monitor it thru my voltmeter. Panther also sells an automatic battery charger, di ko lang alam ang price.
    Kung hindi magagamit, bili ka na lang ng battery maintainer/battery tender/trickle charger, usually ang output nito is 1A or less, just to keep the battery topped up. Pero ang nakikita ko sa sulit is 3k+ din, which for me is di sulit kasi price pa rin ng battery yun. There are lots of How-Tos sa internet kung pano gumawa ng trickle charger. Sinubukan ko dati kaso without a resistor, ayun di kinaya ng adapter yung load ng battery kaya bumigay fuse
    O di kaya let him use it na lang sometimes, para maka circulate ang oils and at the same time macharge ang battery.
    Apr 2010
    Had this solar trickle charger for years and used it whenever I leave to work abroad. Though only 1.5W it certainly helps during long storage and prevents the battery from being flat.
    Aug 2012
    uy, solar powered. that's nice. saan mo nabili at magkano yan dati?
    Aug 2012
    any user of Suoer SON-10A Automatic Battery Charger? feedback naman sa performance. price is P1,600 from OLX.
    Apr 2010
    ^ Padala from a relative sa US. I think $19 bought at Harbor Freight.
    Jul 2013
    Better to ask your brother to start the car engine or maybe use the car for a couple of kms once a week or so. Battery is the least of your concern when leaving a vehicle for extended period of time.
    Sent from my GT-N5100 using Tapatalk 2
    Aug 2012
    guys, i appreciate the suggestion but driving the car is not an option for us.
    i read that starting the car engine will substantially drain more energy from the battery than can be charged back by leaving the engine at idle. mas mabilis daw ma-drain ang battery. tama ba ang info na ito??
    if yes, then kailangan ko pa rin ng battery charger para di mag-flat empty ang battery.
    yespo. idling won't do it. you have to take the car to the road and at speed, in order to sufficiently charge the battery.
    but leaving the trickle charger on, un-attended, might not be a good idea, either.
    what we do, is to charge the battery at regular intervals (q 3 weeks), using more than just a tickle of an amperage. nakikita naman kapag near-full charge na, e. the current meter of the charger will show a significant drop in the amperage. say, from 7 amp to 1 amp..
    it may not be a good idea to let the car remain un-moved for longer periods. yung car namin, hindi ginamit nang 3 weeks.. binahayan ng langgam ang loob ng side skirt.. hirap patayin..
    Meron ctek batt charger sa excellar sa may Banawe cor n.roxas. Around 5k dati yun price ng mid range model. Dami gumagamit Nyan na mga high end na sportscars na Naka garahe Lang. Balak ko din bumili nito. Excellar is also the distributor of recaro, prodrive, adv1 kaya high quality stuff mga benta nila. you can check out the website of ctek Kung ano type mo model.
    Check out mo din pala vendors section ng Subaru club.ph. Nandun is excellar
    Aug 2012
    Quote Originally Posted by jaymd View Post
    nice. maganda ngang brand itong CTEK (Sweden). pricey din similar to deca (Italy). you pay for quality talaga.
    CTEK MSX 5.0 (5A) = P5,000
Smart Car Battery Charger
