Results 1 to 5 of 5
- Apr 2008
- 3
April 28th, 2008 09:30 PM #1ask ko lng po kasi yung charade 94 model nmn,cguro mga 5 km palang tinatakbo tumataas na yung remp gauge nya.pag medyo ngtagal pa tumataas pa halos sagad na lalo na pag trafic!pero kapag arangkada na ulit bumababa nmn sya hannggang gitna.basta taas baba abg gauge nya.ano po kaya may problema?engine or gauge?d nmn po sya umaabot dun sa max na temp sa gauge.d naman nauubusan ng tubig pati.TIA
April 28th, 2008 10:04 PM #2
sir parang accurate pa naman yung gauge niyo kasi kung nahahanginan bababa talaga yan. pero shempre unsafe na yung car if umiinit na.
sir try to look at the hoses and the condition of the radiator kung may bara. did you drain the radiator already? baka din kasi sa mga impurities na nagbabara.
edit: pwede rin yung aux fan ay hindi na gumagana... you can check it if normal running temp or higher, dapat magON na yun.Last edited by archie123456789; April 28th, 2008 at 10:58 PM.
May 1st, 2008 06:47 AM #4
yap ganun din sa palagay ko mukhang ok pa yung gauge mo.
probable cause ay no1- radiator mo barado, no2- aux fan mo sira most common na sira yun. then if all of the above ay ok , baka water pump mo ay may deprensya.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 4th, 2008 05:03 PM #5your radiator is probably clogged na. replace of have it opened and checked.
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
