Results 1 to 12 of 12
    Oct 2008
    Mga sir
    Ask ko lang po kung saan makakabili ng socket or fuse/socket fuse ng alternator connecting to battery ng alternator for 4ja1 engine. Kasi po nirekta po ng gumagawa ng alternator yung socket. tuwing tinatapakan ko po yung accelerate. my sumisipol then naririnig sa speaker. i think yun po yung problema ko na static sounds. thank you po
    Quote Originally Posted by robz02 View Post
    Mga sir
    siguro sa alternator shop. baka nga puedeng sila pa ang mag-install..
    Oct 2008
    Naku sir madami na me panag tanungan. ang tawag daw dun fuse-able daw po iyun. wala po kasi me mahanap para sa 4ja1 na makina.
    Feb 2009
    Mga sir
    that sumisipol is radio frequency interference (RFI) and only happens when you are tuned in to AM. try installing a .27uF capacitor at the BAT terminal and the alternator ground. there could be insufficient ground to the alternator too.
    Jun 2007
    fusible? how about sa battery shop? baka accessories ito
    Oct 2008
    Sir. anu po yung 27uF capacitor? san makakabili po nito. Yun po big problem ko. kahit hindi me naka am or fm radio. naka disk player. ones umaandar me, sumasabay din po yung tunog sa speaker. parang sumisipol po sya. i hope you can solve my problem. thnx po
    alternator whine siguro yan.
    agree. naka-setup ba sounds mo sir?
    Oct 2008
    opo. new na po alternator ko.
    Feb 2009
    you can buy just the capacitor from raon st radio shops or you can buy a more elaborate noise suppressor. add more grounding to your setup
    ipacheck up mo sa reliable na autoshop. baka makuha sa pag layout ng wiring.
    Oct 2008
    mga magkanu po iyun sir. at anu po itsura nun. thank you po.
Problem: saan makakabili ng socket or fuse ata yung from alternator to batt.
