Results 1 to 10 of 10
December 9th, 2010 04:21 PM #1
mag sirs pa help nmn, ganito nangyari, umandar un corolla gli bigbody ko, pero namatay bigla, ayaw na magstart, malakas un redondo, tinulak ayaw pa din.
tumawag na ko mekaniko, bka daw kulang sa gasolina (isang guhit na lang kasi un sa gauge ko), so kinargahan ko naging halos kalahati, pero ayaw pa din.
tinest un distributor, and spark plugs, walang spark, bumili ko ng surplus na distributor and bago na spark plugs, inayos umandar, tapos nun pinatay ko ayaw nnmn umandar, hard starting sya malakas nmn un redondo, tsek un mga fuse oks nmn daw sabi nun mekaniko.
tatlong beses nag start pero pag pinatay halos pahirapan na ulit magstart, tsambahan na lang.
ibalik ko daw un distributor bka me problem un nabili ko. oks nmn high tension wires ko
any suggestions mga sirs. 2days na dito sa ofc un kotse di ko sya magamit. hayyy...
thanks in advance. more power tsikoteers
95 corolla gli un oto ko.
December 9th, 2010 04:34 PM #2
December 9th, 2010 04:48 PM #4
find your toyota diagnostic link connector in the engine compartment and jumper terminals TE1 and E1. thence, turn the ignition to run (on) without running your engine. thence, count the number of blinks of the CEL; e.g.,
O-I I- O-I or code 21 ( blink blink pause blink). then write all the diagnostic trouble codes being displayed starting with the lowest one to the highest and it will repeat the list. send back your DTC's
December 9th, 2010 04:54 PM #5
December 9th, 2010 05:01 PM #6
December 9th, 2010 05:07 PM #7
THE AUTO SPECIALIST
- Mar 2006
- 607
December 9th, 2010 06:41 PM #8you may want to consider this ;
spark test, the spark must be present ( at least 25kv) or 1/4" gap
fuel pressure test ,at least you'll get 30psi key on/engine off
compression test will be done if all the conditions above are right.
most cases the condenser inside the distributor shorts out if you experience a no spark condition.
- Oct 2008
- 59
December 9th, 2010 08:49 PM #9
December 10th, 2010 10:10 AM #10
many thanks sa mga nagreply, try ko lahat sabihin sa mechanic mga suggestions nyo. and sana na maayos na rin yung kotse.
thanks again, will try to update later.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
