Results 1 to 10 of 28
September 9th, 2014 11:33 PM #1
hi guys,
my low beam is not working pero if i flash or use the high beam, ok naman. isang pang observation ko, kapag nag flash ako, mihindi sumasara yun ilaw. nakikita ko na lang na bukas yun ilaw pag nasa parking area na. switching the light on and off wont do it, kelangan laruin yun flash para mag sara. could it be the switch? headlight is H4 btw. thanks!
sent it to RAE last month, wires lang daw problema, now ganun na naman.
September 10th, 2014 05:40 AM #2
Do you have add-ons to the light circuits like aftermarket fig lights ? Try checking the headlight relay first
Posted through phlpost.gov.ph
- Aug 2012
- 61
September 10th, 2014 05:58 AM #3It could be the relay / fuse na nabasa. Ganyan din prob ko pero high beam naman nawawala. Dati mga twice ako pabalik balik sa electrician, nung naulit at nawala na naman ako na tumira at nag-ayos at nalaman ko ang problem ay nababasa ang relay pag nagka-carwash ako at power spray sa hood. Natatalsikan pala sa loob. So ako na nag repair ng relay socket at palit relay na rin kung sira.
Highbeam / Flasher I think iisa lang kaya wala ka prob.
Kung panay ganyan, baka same problem ko rin. Alamin mo kung naka relay ka na at check mo yung socket relay / relay kung medyo nagpu-pulbos, ibig sabihin nun (for me ha) nababasa.
HTH
September 10th, 2014 09:13 AM #4
baka madumi lang yung contact point.. or baka sunog.. anong car?? pag honda pinapalitan yung buong assembly..
- 52,731
September 10th, 2014 09:25 AM #5isang headlight lang, o parehong headlights ang hindi sumasara?
if both lights, baka switch o relay nga.
September 10th, 2014 10:23 AM #6
hi,
parehong headlights ang wala kapag low beam. dyahe naman mag high beam baka ma bad trip kasalubong hehe no other add on lights like fog lights. papa check ko relay sa saturday, sana yun lang sira. mahal pala yun switch, assembly ang bibilhin.
may chance ba nu pundido din ang ilaw? balak ko din kasi magpalit ng bulb, para isahan na.
September 10th, 2014 02:50 PM #9
- Aug 2012
- 2,767
September 10th, 2014 03:01 PM #10
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
